Consolidate FlashHelp/WebHelp
Aug 31, 2012 8:25 AM
I have been asked by my developers if there is any way to consolidate the output from RoboHelp in FlashHelp or WebHelp into one file? Apparently, their stance is that one file is easier/takes less time to install than several smaller files. Or, if there's a way to zip the files, but still access them for help as they "normally would."
My guess is that no, there is no way to do that and still have the output function as a mini-website.
Any insight would be greatly appreciated.
Rich
    Aug 31, 2012 8:29 AM   in reply to RAOmilctr
    Hi there
    Indeed there is. The output is called Microsoft HTML Help and the file extension is .CHM. But the issue is that CHM files don't function on networks unless you jump through hoops. And if you placed the CHM on a web server, it would have to be downloaded and unblocked by the end user before it could be used.
    Cheers... Rick
    Helpful and Handy Links
    RoboHelp Wish Form/Bug Reporting Form
    Begin learning RoboHelp HTML 7, 8 or 9 within the day!
    Adobe Certified RoboHelp HTML Training
    SorcerStone Blog
    RoboHelp eBooks
    Aug 31, 2012 8:35 AM   in reply to RAOmilctr
    Normally the developers just include the entire folder as part of their build process; even if you zipped it, they would still have to un-zip it when installed. Have you looked at other 1-file systems like CHM or locally-installed AIRHelp?
    Aug 31, 2012 8:38 AM   in reply to Jeff_Coatsworth
    LOL, I totally spaced AIR Help. Probably because I don't really consider it to be a "one file deployment". Certainly one file that you distribute is created, but that file cannot be used until the AIR runtime has been installed. Then you have to perform an actual install of the package. Then there's the pesky Digital Certificate that's involved.
    Cheers... Rick
    SorcerStone Blog
    RoboHelp eBooks
    Aug 31, 2012 8:51 AM   in reply to Captiv8r
    That can all be wrapped up in the developer's installer - you apply for & get the license to distribute the run-time (free); you make up your own certificate (free); the developer's installer handles it all silently (in our case at least). Easy-peasy-lemon-squeezy!
    Aug 31, 2012 8:53 AM   in reply to RAOmilctr
    RH10 has a new feature that allows you to skin a CHM with a WebHelp skin - that might jazz it up for you. It all really depends on where it's going to be put - workstation, server, webserver, etc.
    Aug 31, 2012 8:59 AM   in reply to Jeff_Coatsworth
    I agree that the ability to deploy CHM with a skin is cool. Wish I'd thought of it!
    Keep in mind that the same limitations mentioned earlier would exist. Basically what the "Skinned CHM" is, is a CHM container with WebHelp output files inside. The main frame of the CHM window will still be the same. I haven't been able to test this thoroughly. My copy of RoboHelp is having issues so I can't even get into version 10 to play.
    Cheers... Rick
    SorcerStone Blog
    RoboHelp eBooks
    Sep 3, 2012 3:27 AM   in reply to Captiv8r
    I'm not sure I would put FlashHelp at the top of the pile because at some locations Flash will not be permitted. Makes things awkward that.
    @petergrainge
    Sep 4, 2012 11:42 AM   in reply to RAOmilctr
    If not all users can get FlashPlayer, aren't any differences academic?
    I don't think FlashHelp has any functionality that WebHelp does not. It just has a more sexy dress on.
    I would put a bit of slap on WebHelp and run with that as it is more versatile.
    Not aware of any online comparison.
    @petergrainge
