billabong2
When exporting to PDF/X-3 from InDesign, why do my placed RGB images get converted to CMYK?
Sep 4, 2012 3:09 PM
When exporting to PDF/X-3 from InDesign CS6, why do my placed RGB images get converted to CMYK?
I understand that this should not normally happen, as PDF/X-3 supports colour-managed RGB images, as well as CMYK and greyscale images.
    Sep 4, 2012 3:27 PM   in reply to billabong2
    Where are you seeing this conversion?
    Sep 4, 2012 3:45 PM   in reply to billabong2
    I don't use the PDF/X-3 preset, but the transparency flattening space is controlled by ID in the Edit menu, not as part of the export process, per se.
    I'd still like to know where you see the conversion. Are you looking at the Acrobat output preview? That is going to show you the values for the target space you select, so if you've chosen a CMYK profile the valuse will be CMYK, but if you choose an RGB space, you'll see only RGB numbers.
  • Rob Day
    Oct 16, 2007
    Sep 4, 2012 4:04 PM   in reply to billabong2
    If you really don't want any conversions why not PDF/X-4?.
    Sep 4, 2012 4:10 PM   in reply to Rob Day
    Adobe most strongly recommends use of PDF/X-4 export from InDesign (without conversion of any colors - the default for the PDF/X-4 joboptions) for the most reliable PDF publishing workflows!
         - Dov
    Sep 4, 2012 5:27 PM   in reply to billabong2
    I've never used the object inspector before, but I just tried it out with a mixed-mode PDF, and I see multiple images listed, not just the one I click on. Are you sure you're looking at the correct image?
    Sep 5, 2012 4:58 AM   in reply to billabong2
    So why do you think it's been converted to CMYK?
  • Rob Day
    Oct 16, 2007
    Sep 5, 2012 6:38 AM   in reply to Peter Spier
    With PDF/X-3 any page with a transparent object would be all CMYK if the transparency blend space is CMYK. An RGB blend space would stop the conversion, but then you'd have RGB text, which would eventually separate to 4-color. I can't see the advantage of X-3 over X-4
