When exporting to PDF/X-3 from InDesign CS6, why do my placed RGB images get converted to CMYK?
I understand that this should not normally happen, as PDF/X-3 supports colour-managed RGB images, as well as CMYK and greyscale images.
I don't use the PDF/X-3 preset, but the transparency flattening space is controlled by ID in the Edit menu, not as part of the export process, per se.
I'd still like to know where you see the conversion. Are you looking at the Acrobat output preview? That is going to show you the values for the target space you select, so if you've chosen a CMYK profile the valuse will be CMYK, but if you choose an RGB space, you'll see only RGB numbers.
