Ron Hodges
Mute channel of audio clip
Sep 4, 2012 1:20 PM
Is it possible in Premiere Elements 10 to mute one channel (l or r) of a particular audio clip on the timeline?
    Sep 4, 2012 1:56 PM   in reply to Ron Hodges
    In Sceneline view, clickk on the Track Header to the left of the audio track and a slider will appear.
    Unfortunately, Sceneline view is limited to only one video and a couple of audio tracks.
    You can also, in Timeline view, just drag the yellow lines across every clip down -- but there's no way to do it to an entire track at once.
    Sep 4, 2012 2:46 PM   in reply to Ron Hodges
    Hi
    There are two ways using which we can mute the audio.
    1. Do one of the following in the Timeline:
      • If the clip is linked to video, Alt‑click the audio track of the clip in the Timeline to select just the audio portion.
      • If the clip is not linked to video, click the clip to select it.
    2. Choose Clip > Enable. (When you disable a clip, the check mark disappears next to the option in the clip menu, and the clip name dims in the track.)
    Hope it Helps
    Sep 5, 2012 5:14 AM   in reply to Ron Hodges
    If you want mono-sound, rather than channel mute, you can use the fill left or fill right audio effect.
    Cheers,
    Neale
    Insanity is hereditary, you get it from your children
    Sep 6, 2012 3:00 PM   in reply to Ron Hodges
    When I need to split channels in a 2-channel Audio file, in PrElements, I Share just that Audio to an intermediate file, and edit that in Adobe Audition, however, the free audio-editor, Audacity, will do it too.
    In PrPro, one can Split Audio in a 2-channel, or 6-channel Audio file, and then edit each channel independently. Maybe PrE 11 will add that capability.
    Good luck,
    Hunt
