I have lets say 3 clips.
long - short - long
I want to create transition between 2nd and 3rd but the 2nd clip is so short, that the transition looks not good
The best effect I will have if the transition could also overlaps clip 1st.
So this is what is possible:
_____|------------|
long - short - long
and this is what I want to be possible:
_|------------------|
long - short - long
Any ideas how to do this?
Only thing I managed to think of is to render only 1st and 2nd and reinsert them to timeline.
You need at least 1 second of transitional material beyond the beginning or end of your clip to create a smooth transition. Longer if it's a longer transition. In other words, if you have a two second clip and you want a two second transition, you will see the transition -- but as soon as it's over the clip will end!
The only alternative is to force the program to work without transitional material. In this case, you'll end up with a freeze frame through the transition, then your clip will start.
You can adjust the Duration of a Transition. With Stop Motion, and similar, I often go with a Transition, that is quite short, about half the Duration of each Still Image. If one is doing many shorter Transitions, the Default Duration (both for Video & Audio) can be set in Edit>Preferences. If one needs a particular Transiton to be longer, then it can be adjusted for Duration manually.
With Video, one does need Handles, as Steve mentions. This article goes into more detail on Handles, what they are, and how they affect Video Transitions: http://forums.adobe.com/thread/701768?tstart=60
Good luck,
Hunt
You missunderstood me.
I dont have that short clips, that transitions look bad.
I have 3 clips and I want to add transition that will cover all 3 of them
at once.
For example Smooth transition to white over those 3 clips. Not only between
2 of them.
So either I can render 2 of them to 1 and then between rendered and 3rd
apply transition or maybe and I hope, there is a different way to do that.
2012/9/4 Bill Hunt <forums@adobe.com>
Re: Transition between few short clips
created by Bill Hunt <http://forums.adobe.com/people/the_wine_snob> in *Premiere
Elements* - View the full discussion<http://forums.adobe.com/message/4672042#4672042
Add a white color matte (Tasks Pane> New Item> Color Matte ...) to your timeline above the other video tracks. Stretch it to cover the start - end of the whiteout and keyframe its opacity to give the fade-in / fade-out effect.
Cheers,
Neale
Insanity is hereditary, you get it from your children
Yes, you've definitely got us confused, gemgreg.
I'm not sure what you mean by "add a transition that will cover all 3 of them at once" and "not between them". Transitions are, by definition, BETWEEN CLIPS.
It sounds as though you may just be fading to black (or white). But how will you have all three clips onscreen at the same time?
If you're proposing to have one clip followed by the next followed by the next, all the while fading to black or white, that's easy enough to do. But you really need to be clear on what exactly it is you're trying to do.
I'm sorry, my english isn't that good. I thought I explained myself well.
It is about one clip followed by the next followed by the next. Transition
is by definition between two clips. Thats true. And I want to put it
between 2nd and 3rd clip.
Transitions begin and end points can be moved, so it can overlap either 2nd
clip or 3rd clip in my example. Problem is that I want to move transition
begin point more to the back so it even overlap 1st clip.
Here I created some kind of screen and changed it a bit to explain:
https://dl.dropbox.com/u/76100105/transitions.png
2012/9/5 Steve Grisetti <forums@adobe.com>
created by Steve Grisetti <http://forums.adobe.com/people/Steve+Grisetti>in
Premiere Elements - View the full discussion<http://forums.adobe.com/message/4674568#4674568
Okay, here's what you need to do.
Open a separate project with just the two or three clips you want to use in your transition sequence. Put them on the timeline and then use Share/Computer to output them.
If you're working in standard definition video, use Share/Computer/AVI with the DV preset.
If you're working in high definition video, use Share/Computer/MPEG with the AVCHD 1920x1080i option.
This will create a single clip that includes your three video segments.
Put this new clip on your timeline and you should be able place your long transition over it.
As I thought, that's the only way to do it. Thank you very much to confirm
it
I think there should be an easier way to do that in Adobe Premiere,
by grouping clips for example.
2012/9/6 Steve Grisetti <forums@adobe.com>
Re: Transition between few short clips created by Steve Grisetti<http://forums.adobe.com/people/Steve+Grisetti>in
Premiere Elements - View the full discussion<http://forums.adobe.com/message/4678072#4678072
thats briliant idea
I missed that post as I replay via email
Great
idea! thx
2012/9/7 nealeh <forums@adobe.com>
created by nealeh <http://forums.adobe.com/people/nealeh> in *Premiere
Elements* - View the full discussion<http://forums.adobe.com/message/4681751#4681751
GemGreg2,
Glad that Neale's workflow was what you needed! As he states, there are often many ways to accomplish the same end.
Good luck, and happy editing!
Hunt
PS - If Neale's method got you what you needed, please see this article: http://forums.adobe.com/thread/1058744?tstart=0
thx. Your idea was also great. It was the first thing I was thinking of
about how to do that.
2012/9/8 Bill Hunt <forums@adobe.com>
Elements* - View the full discussion<http://forums.adobe.com/message/4683082#4683082
