RunDLL or sp.dll problem
Sep 5, 2012 6:14 AM
Hello:
For the last few months, whenever I restart my computer, I get the following  message:
"RunDLL" is in the top border of the window.
The body of the error message says "There was a problem starting C;\Users\MyName\AppData\Roaming\Adobe\sp.dll The specified module could not be found".
I am running Windows 7 Home Premium on a Dell Inspiron laptop with 4 GB memory.
Does anyone know how to solve this problem? I was thinking about deleting Adobe from the computer and then re-downloading it, but I am not sure if that is necessary or advisable.
Thanks.
JMattero
    Sep 5, 2012 6:30 AM   in reply to JMattero
    I am very concerned that this might not be an Adobe file at all, but a virus or similar hiding in an Adobe folder. However...the message seems to actually say that the file sp.dll doesn't exist. That might be a good sign. Have you had an antivirus (or antispyware) fix anything at the time this started?
    Uninstalling Adobe Reader isn't likely to make the slightest difference, I don't think it's involved.
    Sep 5, 2012 6:48 AM   in reply to JMattero
    Well, as I said it is possible that the virus is already gone. The message seems to clearly show that a file is not there - just that whatever removed the virus left this (harmless?) effect behind.
    Sep 5, 2012 6:49 AM   in reply to Test Screen Name
    By the way, if you are satisified the virus is gone you can just stop whatever is trying to run it. Maybe this will work... From a run box type 'msconfig' and select the Startup Tab. You can uncheck the applications you wish to stop from loading with windows
    Sep 5, 2012 11:14 PM   in reply to JMattero
    Yes, that is exactly what is causing that error popup during Windows startup.  Delete or disable it.
Incoming Links
