Hi i contact Adobe a few mounths ago i sent files to them and there no solution yet for this problem: I bought the Adobe CS6.0 and i cant work with my XD Cam EX files. Is there a solution for this or should i ask my money back from adobe?
Case number #0183368749
Regards
David Luis
I will look into the status of your case.
Update: Your case is part of an ongoing bug that we are working to resolve as quickly as we can, with artifacts in XDCAM footage. Keep an eye out for any status updates, and make sure to keep your software up-to-date. You can also transcribe your footage before use as a workaround.
Please understand this is a high-priority for us.
Just to let you know, if there is an issue in our software, we will work on resolving it as fast as we can. We have to identify the issue, find a resolution for it, and make sure that resolution can be distributed to everyone safely. Please, be patient, we are working to resolve this. If you have any deeper concerns, please send me a private message - I do not want to discuss specifics of your case in a public forum.
Just know that we are here, we are listening, and we are working to make everyone's experiences the best we can.
Hi Greg
Any news about XDCAM EX files.
Is there Something i can do?
I hope you understand but i need to work those file. A lot of my work are
XDCAM EX files and i only got 2 computers. One has the CS5.5 and the other
one has CS6.0.
.It helps if i install a english version of Windows 7
I hope you could understand my situation
Kind Regards
David Luis
2012/8/21 lasvideo <forums@adobe.com>
Re: XD CAM EX footage
created by lasvideo <http://forums.adobe.com/people/lasvideo> in *Premiere
Pro CS5, CS5.5, & CS6* - View the full discussion<http://forums.adobe.com/message/4637732#4637732
Hi Greg.
Can you please tell me witch better format to transcode the footage?
Regards
2012/9/4 Greg Baber <forums@adobe.com>
created by Greg Baber <http://forums.adobe.com/people/Greg+Baber> in *Premiere
Pro CS5, CS5.5, & CS6* - View the full discussion<http://forums.adobe.com/message/4672280#4672280
I would suggest the codec that most professional video production companies standardize to these days which is DNxHD.
UT is lossless and will reate HUMONGOUS files.
DNxHD is subtle compression in a much more reasonable file sizes. It is widely embrced by the industry for a good reason. It looks great and is a managable size. It available for PC and MAC and is the Avid standard.
I am not Jim, but I maybe can help you out.
I think it should be this one you should have:
http://umezawa.dyndns.info/archive/utvideo/utvideo-11.1.1-win.exe
It is all at the buttom of the page.
/Ulf
Thanks for help me.
Can you explain me how i transcode the footage.
Sorry body you but if is possible explain me all process to transcode the
footage.
Kind Regards
David Luis
2012/9/5 UlfLaursen <forums@adobe.com>
created by UlfLaursen <http://forums.adobe.com/people/UlfLaursen> in *Premiere
Pro CS5, CS5.5, & CS6* - View the full discussion<http://forums.adobe.com/message/4674578#4674578
Hi Greg
Sorry again but i star 2 projects with CS6.0 and i cant go back to CS 5.5.
I need to finished the projects and ive got the same issue
footage With the codec.
Can you tell me how i can sent you a private massage?
Kind Regards
David Luis
People in the past have had luck putting the file into Adobe Media Encoder. You can drag and drop you files into the program.
Then, click the hyperlink under Preset to change the output info. The format should be AVI if you have UT installed, if you have DNxHD installed, then the format is Quicktime.
Once you chosed the correct format, in the video tab there will be a codec drop down. There you can find the codec you are transcoding to.
Thanks Greg for your help.
i hope you understand my situation
Regards
David Luis
2012/9/5 Greg Baber <forums@adobe.com>
Re: XD CAM EX footage created by Greg Baber<http://forums.adobe.com/people/Greg+Baber>in
Premiere Pro CS5, CS5.5, & CS6 - View the full discussion<http://forums.adobe.com/message/4675907#4675907
Thanks a lot for your help
Regards
David Luis
2012/9/5 lasvideo <forums@adobe.com>
Pro CS5, CS5.5, & CS6* - View the full discussion<http://forums.adobe.com/message/4675873#4675873
