CS4, "The installation database is corrupt"
Aug 31, 2012 3:18 PM
Tags: #cs4 #corrupt_databse
Help!  Wanted to install this on my new PC. I had no problems originally installing it on my older PC.  I have disks...but can't get past disk #1.  i don't want to deactivate it from the old PC, if I can't get it back.
I'm getting nowhere fast.  Any suggestions?  Thanks!
Rosemary
    Aug 31, 2012 3:59 PM   in reply to chasingproblems
    Can you please try copying the install files to your desktop to check to see if you receive a disc error.  If you do then it is likely your installation media has been damaged.  You can download a fresh copy of the install files by following the directions listed at http://prodesigntools.com/download-adobe-cs4-and-cs3-free-trials-here. html.
    Aug 31, 2012 8:05 PM   in reply to chasingproblems
    Chasing Problems, you are getting that 404 error because you did not read the instructions properly. Please read the download instructions present on the same page and i am sure you will be able to download it without any issues.
    Sep 4, 2012 6:30 PM   in reply to Jeff A Wright
    I have the same challenge.  When I download the three CS4 files from the suggested site, the downloads are not application files and won't extract?
    Since my first post I edited the file extensions to exe and they extracted.  But when I run the set up file I get the same message as before.....installation datebase is corrupt contact adobe support
    I am running windows 7 on a new machine
    Sep 5, 2012 9:28 AM   in reply to 75Sierra
    What are the name of the files which you end up download 75Sierrra?
    Sep 5, 2012 10:41 AM   in reply to chasingproblems
    The 7zip file contains the compressed archive for the install files.  You can run the exe file to extract the 7z file.
    Sep 5, 2012 1:06 PM   in reply to Jeff A Wright
    Jeff, I have exactly the same issue.  Everything unzipped and looks like the same file structure as on my old machine.  I first took my original install files and it gave me the first message.  Them I followed instruction re the trial download and have exactly the same MSG.  I am also running w 7 64 bit.
    My Lightroom installed perfectly, but cs4 won't run the setup file.
    No idea but assume some conflict with win 7.
    Suggestions?
    Sent from my iPhone
    Sep 5, 2012 1:55 PM   in reply to 75Sierra
    Download and extracting the install files is a separate issue from the error the Installation Database is corrupt.  Please see Error "...Installer Database is Corrupt..." when you install Adobe Creative Suite 3 products - http://helpx.adobe.com/creative-suite/kb/error-installer-database-corr upt-install-1.html for details on how to resolve this difficulty.
    Sep 5, 2012 3:23 PM   in reply to chasingproblems
    Problem solved.  Mine was a new machine and came with Adobe premiere elements 10 installed. I went into program/adobe/adobe elements 10 directory and found a caps.db file.  Renamed to xcap and wallah….cs 4 installed no problem.
    Thanks Jeff re the caps file, I did not see that conflict mentioned anywhere on corrupt install info.  The new machine bit me as I knew I didn’t have cs3 installed!
    Good luck Chasing Problems.  Odds maybe that you have an adobe preinstall on yours as well.  Simple fix once you know it.
    Sep 5, 2012 5:37 PM   in reply to chasingproblems
    Perhaps u should un install PE 10 and then try.
    Jan 2, 2013 11:22 AM   in reply to chasingproblems
    just wanted to say thanks.  i had pretty much the exact same problem and chasingproblems and this thread saved me a lot of time and frustration.
    Jun 18, 2013 8:26 PM   in reply to kanukato
    HELP!
    Hi There, I have a valid purchased key of Adobe CS4 Web Premium but upon rebuilding my laptop I need to download Adobe CS4 Web Premium. Does ayone know where I can still get hold of this version please?
    Thanks in advance.
