what to do here?
Aug 30, 2012 8:14 AM
Photoshop 13.0.1 update for Photoshop CS6 and Photoshop CS6 Extended
Done with Errors. Error Code: U44M1P6
Adobe Extension Manager CS6 Update
Installation failed. Error Code: U44M1P7
Branched to a new discussion.
    Aug 30, 2012 8:28 AM   in reply to toddfrizzell
    Hi
    Please follow the below mentioned articles and we will be able to resolve the concern
    http://helpx.adobe.com/creative-suite/kb/unable-apply-extension-manage r-update.html
    http://helpx.adobe.com/creative-suite/kb/error-u44m1p7-installing-upda tes-ccm.html
    Hope It Helps
    Aug 30, 2012 12:12 PM   in reply to toddfrizzell
    If you're getting that error during install, try the 13.0.1 update manually:
    It can be downloaded here:
    Windows:
    http://www.adobe.com/support/downloads/detail.jsp?ftpID=5408
    Mac:
    http://www.adobe.com/support/downloads/detail.jsp?ftpID=5407
    Aug 30, 2012 5:23 PM   in reply to toddfrizzell
    If you (or anyone) have received this error (Error U44M1P6) while updating to Photoshop 13.0.1, we'd like to know about it.
    Please attach and send me the patch logs from these locations:
    Mac Logs:
    Mac logs:   <root volume>/Library/Logs/Adobe/Installer
    Windows Logs:
    Win32:   C\Program Files\Common Files\Adobe\Installers
    Win64:  C\Program Files (x86)\Common Files\Adobe\Installers
    To this address: petgreen (at) adobe (dot) com
    Aug 31, 2012 4:37 PM   in reply to toddfrizzell
    Todd,
    Have you had any prerelease and/or beta versions of Photoshop installed on your system previously?
  • PECourtejoie
    Jan 11, 2006
    Sep 1, 2012 10:44 AM   in reply to toddfrizzell
    Hello!
    By any chance, did you disable any plug-in/extension by adding a tilde ~ in front?
    Another user had the issue (he found it out in the logs): http://forums.adobe.com/message/4665640#4665640
    Pete, it might be useful to sent that info to the update/install engineers.
    Sep 3, 2012 1:37 PM   in reply to Pete.Green
    Here is my error log
    Visit http://www.adobe.com/go/loganalyzer/ for more information
    START - Installer Session
    RIBS version: 6.0.98.0
    OSX version: 10.7.4
    ::START TIMER:: [Total Timer]
    CHECK: Single instance running
    CHECK : Credentials
    Load Deployment File
    deploymentFile option not given
    CHECK : Another Native OS installer already running
    Create Required Folders
    Assuming install mode
    Looking up install source path
    Sync Media DB ...
    ::START TIMER:: [Sync Media DB]
    Pre check media db sync
    End of Pre check media db sync. Exit code: 0
    :: END TIMER :: [Sync Media DB] took 638 milliseconds (0.638 seconds) DTR = 583.072 KBPS (0.569406 MBPS)
    Ready to initialize session to start with ...
    ::START TIMER:: [CreatePayloadSession]
    -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
    Updated source path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6
    Updating media info for: {05F4F74F-F432-41A5-8C0F-D0CE27DF43A6}
    Ignoring original data since install source is local
      Type: 0, Volume Order: 1, Media Name: Adobe Photoshop CS6
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-ru_RU-130812102134/AdobePhotoshop13-ru_ RU-130812102134.dmg
    Updating media info for: {0C0D5FFE-5163-4C31-99A8-67E101BFE989}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-cs_CZ-130812101708/AdobePhotoshop13-cs_ CZ-130812101708.dmg
    Updating media info for: {199CF0F4-7D40-4040-971D-D4DC22FAD746}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-uk_UA-130812102303/AdobePhotoshop13-uk_ UA-130812102303.dmg
    Updating media info for: {22B297EF-8769-4482-BC5C-23FA225E4D22}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-sv_SE-130812101243/AdobePhotoshop13-sv_ SE-130812101243.dmg
    Updating media info for: {2AD0D397-31E7-4702-921A-3D0457CDA9F0}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-zh_CN-130812095757/AdobePhotoshop13-zh_ CN-130812095757.dmg
    Updating media info for: {52311082-D399-4BC8-91B8-EE90D7DD3797}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-en_IL-130812102727/AdobePhotoshop13-en_ IL-130812102727.dmg
    Updating media info for: {554A7BA9-8879-496E-BC3D-93650613DDE5}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-Support-130812103612/AdobePhotoshop13-S upport-130812103612.dmg
    Updating media info for: {686EDFB9-5454-47D4-9272-182A4D7A447C}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-en_AE-130812102559/AdobePhotoshop13-en_ AE-130812102559.dmg
    Updating media info for: {6A166824-93B4-483B-B719-38603EC354EE}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-hu_HU-130812102431/AdobePhotoshop13-hu_ HU-130812102431.dmg
    Updating media info for: {6F660A0B-5C68-476C-8829-D922B03B5124}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-pt_BR-130812100053/AdobePhotoshop13-pt_ BR-130812100053.dmg
    Updating media info for: {76B845AC-61A5-4A2A-8B2B-E8C0A2C5C461}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-es_ES-130812101115/AdobePhotoshop13-es_ ES-130812101115.dmg
    Updating media info for: {79254C4B-C13F-47A0-A9C9-914A9A2C167A}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-it_IT-130812100351/AdobePhotoshop13-it_ IT-130812100351.dmg
    Updating media info for: {7F5EF61F-3FD6-4710-9289-A9FAD5CBBA1D}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-fi_FI-130812101411/AdobePhotoshop13-fi_ FI-130812101411.dmg
    Updating media info for: {9F58F6CE-D903-4AA6-9812-5748390B9643}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-da_DK-130812100222/AdobePhotoshop13-da_ DK-130812100222.dmg
    Updating media info for: {A16E2190-73DD-4823-89AB-224F2AF89690}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-fr_FR-130812100648/AdobePhotoshop13-fr_ FR-130812100648.dmg
    Updating media info for: {A41B2BD4-0697-4267-8D8A-A83B5DAD08B4}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-zh_TW-130812095629/AdobePhotoshop13-zh_ TW-130812095629.dmg
    Updating media info for: {B040AE9B-41F3-4AA1-89C5-C29003C87389}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-en_GB-130812095201/AdobePhotoshop13-en_ GB-130812095201.dmg
    Updating media info for: {B16E4780-1569-464F-8405-D4BF620E0373}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-tr_TR-130812102006/AdobePhotoshop13-tr_ TR-130812102006.dmg
    Updating media info for: {C3411DF1-0D93-4437-9233-05FFCBC789F4}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-es_MX-130812100946/AdobePhotoshop13-es_ MX-130812100946.dmg
    Updating media info for: {D8560CFF-756D-4259-A42A-0C9C41D6D638}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-ja_JP-130812095332/AdobePhotoshop13-ja_ JP-130812095332.dmg
    Updating media info for: {DBD9DF05-1D69-4F31-9154-927F9F808013}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-nl_NL-130812100520/AdobePhotoshop13-nl_ NL-130812100520.dmg
    Updating media info for: {DE32ABBD-DEB4-45A8-958E-0C574655BE58}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-nb_NO-130812101540/AdobePhotoshop13-nb_ NO-130812101540.dmg
    Updating media info for: {E5D5D587-B139-4251-8B6C-0FF28927F9D1}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-pl_PL-130812101837/AdobePhotoshop13-pl_ PL-130812101837.dmg
    Updating media info for: {E848088E-1919-4BE4-9D2E-B168EDA8CF49}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-ko_KR-130812095502/AdobePhotoshop13-ko_ KR-130812095502.dmg
    Updating media info for: {E92B626B-A0D8-4DCA-A1C9-E474FBD969AE}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-fr_MA-130812102854/AdobePhotoshop13-fr_ MA-130812102854.dmg
    Updating media info for: {ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-Core-130812103054/AdobePhotoshop13-Core -130812103054.dmg
    Updating media info for: {FA65AB82-B627-442B-B2D0-991CEB0EA1B4}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-fr_CA-130812100817/AdobePhotoshop13-fr_ CA-130812100817.dmg
    Updating media info for: {FB5A3F35-F507-4FD4-956C-505CFA446FEB}
      Path: /Users/Michelles MBP/Library/Caches/Adobe/AAMUpdater/AdobePhotoshopCS6Support-13.0/13. 0.1/Adobe Photoshop CS6/payloads/AdobePhotoshop13-de_DE-130812095924/AdobePhotoshop13-de_ DE-130812095924.dmg
    --------------------  END  - Updating Media Sources -  END  --------------------
    Supported RIBS version range: [0.0.66.0,6.0.98.0]
    ----------------- CreatePayloadSession: machine is x86 ---------------
    [       0] Mon Sep  3 12:48:25 2012  INFO
    ______ Verify Dependency Subscribers ______
    [       0] Mon Sep  3 12:48:25 2012 ERROR
    DW023: The extension payload: {05F4F74F-F432-41A5-8C0F-D0CE27DF43A6} Adobe Photoshop CS6 Russian Language Pack_13.0.1_AdobePhotoshop13-ru_RU 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Russian Language Pack_AdobePhotoshop13-ru_RU
              MinVersion: 0.0.0.0
              This parent relationship is not satisfied, because this payload is not present in this session.
              This payload will be ignored in this session.
    DW023: The extension payload: {0C0D5FFE-5163-4C31-99A8-67E101BFE989} Adobe Photoshop CS6 Czech Language Pack_13.0.1_AdobePhotoshop13-cs_CZ 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Czech Language Pack_AdobePhotoshop13-cs_CZ
              MinVersion: 0.0.0.0
    DW023: The extension payload: {199CF0F4-7D40-4040-971D-D4DC22FAD746} Adobe Photoshop CS6 Ukrainian Language Pack_13.0.1_AdobePhotoshop13-uk_UA 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Ukrainian Language Pack_AdobePhotoshop13-uk_UA
              MinVersion: 0.0.0.0
    DW023: The extension payload: {22B297EF-8769-4482-BC5C-23FA225E4D22} Adobe Photoshop CS6 Swedish Language Pack_13.0.1_AdobePhotoshop13-sv_SE 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Swedish Language Pack_AdobePhotoshop13-sv_SE
              MinVersion: 0.0.0.0
    DW023: The extension payload: {2AD0D397-31E7-4702-921A-3D0457CDA9F0} Adobe Photoshop CS6 Chinese Language Pack_13.0.1_AdobePhotoshop13-zh_CN 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Chinese Language Pack_AdobePhotoshop13-zh_CN
              MinVersion: 0.0.0.0
    DW023: The extension payload: {52311082-D399-4BC8-91B8-EE90D7DD3797} Adobe Photoshop CS6 IL English Language Pack_13.0.1_AdobePhotoshop13-en_IL 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 IL English Language Pack_AdobePhotoshop13-en_IL
              MinVersion: 0.0.0.0
    DW023: The extension payload: {686EDFB9-5454-47D4-9272-182A4D7A447C} Adobe Photoshop CS6 AE English Language Pack_13.0.1_AdobePhotoshop13-en_AE 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 AE English Language Pack_AdobePhotoshop13-en_AE
              MinVersion: 0.0.0.0
    DW023: The extension payload: {6A166824-93B4-483B-B719-38603EC354EE} Adobe Photoshop CS6 Hungarian Language Pack_13.0.1_AdobePhotoshop13-hu_HU 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Hungarian Language Pack_AdobePhotoshop13-hu_HU
              MinVersion: 0.0.0.0
    DW023: The extension payload: {6F660A0B-5C68-476C-8829-D922B03B5124} Adobe Photoshop CS6 Brazilian Portugese Language Pack_13.0.1_AdobePhotoshop13-pt_BR 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Brazilian Portugese Language Pack_AdobePhotoshop13-pt_BR
              MinVersion: 0.0.0.0
    DW023: The extension payload: {76B845AC-61A5-4A2A-8B2B-E8C0A2C5C461} Adobe Photoshop CS6 Spanish Language Pack_13.0.1_AdobePhotoshop13-es_ES 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Spanish Language Pack_AdobePhotoshop13-es_ES
              MinVersion: 0.0.0.0
    DW023: The extension payload: {79254C4B-C13F-47A0-A9C9-914A9A2C167A} Adobe Photoshop CS6 Italian Language Pack_13.0.1_AdobePhotoshop13-it_IT 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Italian Language Pack_AdobePhotoshop13-it_IT
              MinVersion: 0.0.0.0
    DW023: The extension payload: {7F5EF61F-3FD6-4710-9289-A9FAD5CBBA1D} Adobe Photoshop CS6 Finnish Language Pack_13.0.1_AdobePhotoshop13-fi_FI 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Finnish Language Pack_AdobePhotoshop13-fi_FI
              MinVersion: 0.0.0.0
    DW023: The extension payload: {9F58F6CE-D903-4AA6-9812-5748390B9643} Adobe Photoshop CS6 Danish Language Pack_13.0.1_AdobePhotoshop13-da_DK 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Danish Language Pack_AdobePhotoshop13-da_DK
              MinVersion: 0.0.0.0
    DW023: The extension payload: {A16E2190-73DD-4823-89AB-224F2AF89690} Adobe Photoshop CS6 French Language Pack_13.0.1_AdobePhotoshop13-fr_FR 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 French Language Pack_AdobePhotoshop13-fr_FR
              MinVersion: 0.0.0.0
    DW023: The extension payload: {A41B2BD4-0697-4267-8D8A-A83B5DAD08B4} Adobe Photoshop CS6 Chinese (traditional) Language Pack_13.0.1_AdobePhotoshop13-zh_TW 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Chinese (traditional) Language Pack_AdobePhotoshop13-zh_TW
              MinVersion: 0.0.0.0
    DW023: The extension payload: {B040AE9B-41F3-4AA1-89C5-C29003C87389} Adobe Photoshop CS6 International English Language Pack_13.0.1_AdobePhotoshop13-en_GB 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 International English Language Pack_AdobePhotoshop13-en_GB
              MinVersion: 0.0.0.0
    DW023: The extension payload: {B16E4780-1569-464F-8405-D4BF620E0373} Adobe Photoshop CS6 Turkish Language Pack_13.0.1_AdobePhotoshop13-tr_TR 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Turkish Language Pack_AdobePhotoshop13-tr_TR
              MinVersion: 0.0.0.0
    DW023: The extension payload: {C3411DF1-0D93-4437-9233-05FFCBC789F4} Adobe Photoshop CS6 North American Spanish Language Pack_13.0.1_AdobePhotoshop13-es_MX 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 North American Spanish Language Pack_AdobePhotoshop13-es_MX
              MinVersion: 0.0.0.0
    DW023: The extension payload: {D8560CFF-756D-4259-A42A-0C9C41D6D638} Adobe Photoshop CS6 Japanese Language Pack_13.0.1_AdobePhotoshop13-ja_JP 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Japanese Language Pack_AdobePhotoshop13-ja_JP
              MinVersion: 0.0.0.0
    DW023: The extension payload: {DBD9DF05-1D69-4F31-9154-927F9F808013} Adobe Photoshop CS6 Dutch Language Pack_13.0.1_AdobePhotoshop13-nl_NL 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Dutch Language Pack_AdobePhotoshop13-nl_NL
              MinVersion: 0.0.0.0
    DW023: The extension payload: {DE32ABBD-DEB4-45A8-958E-0C574655BE58} Adobe Photoshop CS6 Norwegian Language Pack_13.0.1_AdobePhotoshop13-nb_NO 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Norwegian Language Pack_AdobePhotoshop13-nb_NO
              MinVersion: 0.0.0.0
    DW023: The extension payload: {E5D5D587-B139-4251-8B6C-0FF28927F9D1} Adobe Photoshop CS6 Polish Language Pack_13.0.1_AdobePhotoshop13-pl_PL 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Polish Language Pack_AdobePhotoshop13-pl_PL
              MinVersion: 0.0.0.0
    DW023: The extension payload: {E848088E-1919-4BE4-9D2E-B168EDA8CF49} Adobe Photoshop CS6 Korean Language Pack_13.0.1_AdobePhotoshop13-ko_KR 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Korean Language Pack_AdobePhotoshop13-ko_KR
              MinVersion: 0.0.0.0
    DW023: The extension payload: {E92B626B-A0D8-4DCA-A1C9-E474FBD969AE} Adobe Photoshop CS6 MA French Language Pack_13.0.1_AdobePhotoshop13-fr_MA 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 MA French Language Pack_AdobePhotoshop13-fr_MA
              MinVersion: 0.0.0.0
    DW023: The extension payload: {FA65AB82-B627-442B-B2D0-991CEB0EA1B4} Adobe Photoshop CS6 Canadian French Language Pack_13.0.1_AdobePhotoshop13-fr_CA 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 Canadian French Language Pack_AdobePhotoshop13-fr_CA
              MinVersion: 0.0.0.0
    DW023: The extension payload: {FB5A3F35-F507-4FD4-956C-505CFA446FEB} Adobe Photoshop CS6 German Language Pack_13.0.1_AdobePhotoshop13-de_DE 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              ProductName: Adobe Photoshop CS6 German Language Pack_AdobePhotoshop13-de_DE
              MinVersion: 0.0.0.0
    BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
      {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0: 0 (0,0)
      {ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD} Adobe Photoshop CS6 Core_13.0.1_AdobePhotoshop13-Core 13.0.1.0: 0 (0,0)
    END Operation order for all session payloads: mediaGroup (requires,satisfies)
    Patch {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0 can be applied to product {1F955A4A-F365-4379-AEE2-B7C83E1AA883} Adobe Photoshop CS6 Support 13.0.0.0
    Patch {ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD} Adobe Photoshop CS6 Core_13.0.1_AdobePhotoshop13-Core 13.0.1.0 can be applied to product {9124DF4E-617D-486B-A970-8FA632244F24} Adobe Photoshop CS6 Core 13.0.0.0
    [       0] Mon Sep  3 12:48:27 2012  INFO
    Overwrite property "extensionsOnly" to: 1
    Overwrite property "mode" to: silent
    Overwrite property "patchesOnly" to: 1
    Overwrite property "workflow" to: updater
    Found payload actions:
    Deciding what installer mode to use...
    BEGIN Setting requested payload actions
    Value returned on lookup of payload: {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0 is: false
    Action string for {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0  is install
    Value returned on lookup of payload: {ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD} Adobe Photoshop CS6 Core_13.0.1_AdobePhotoshop13-Core 13.0.1.0 is: false
    Action string for {ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD} Adobe Photoshop CS6 Core_13.0.1_AdobePhotoshop13-Core 13.0.1.0  is install
    END Setting requested payload actions
    Collected advanced path check information for INSTALLDIR
    INSTALLDIR is a well-formed path
    INSTALLDIR is not the root path
    INSTALLDIR is on a local volume
    INSTALLDIR is on a writable volume
    INSTALLDIR is not on a case sensitive volume
    INSTALLDIR passed path basic path validation: /Applications
    [       0] Mon Sep  3 12:48:38 2012  INFO
    BEGIN InstallOperationsQueue Unordered operations
      {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0:  with operation install
      {ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD} Adobe Photoshop CS6 Core_13.0.1_AdobePhotoshop13-Core 13.0.1.0:  with operation install
    END InstallOperationsQueue Unordered operations
    BEGIN InstallOperationsQueue Ordered operations
    END InstallOperationsQueue Ordered operations
    Payloads passed preflight validation.
    Call PreSession Custom Hook
    [       0] Mon Sep  3 12:48:39 2012  INFO
    Calling the custom action code for pre-install for payload {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0
    ::START TIMER:: [Payload Operation :{554A7BA9-8879-496E-BC3D-93650613DDE5}]
    [       1] Mon Sep  3 12:48:39 2012  INFO
    Installer Operation: PayloadInstaller
    Request to install payload
    Payload {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE6/resources
    [       1] Mon Sep  3 12:48:41 2012  INFO
    CustomizedPatch property not found in database
    Beginning installation for payload at /private/tmp/.tempdir83Az3krq/Install.db
    Attempting to patch file: "/Library/Application Support/Adobe/Adobe Photoshop CS6/patcher_trigger/patchTrigger"(Seq 3)
    Completing installation for payload at /private/tmp/.tempdir83Az3krq/Install.db
    UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{554A7BA9-8879-496E-BC3D-93650613DDE5}.db
    [       0] Mon Sep  3 12:48:41 2012  INFO
    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
    :: END TIMER :: [Payload Operation :{554A7BA9-8879-496E-BC3D-93650613DDE5}] took 1818 milliseconds (1.818 seconds) DTR = 77.0077 KBPS (0.0752028 MBPS)
    User specified overrideFile:
    Successfully updated the csu inventory for {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0 return values 0:0
    Calling the custom action code for post-install for payload {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0
    [       0] Mon Sep  3 12:48:42 2012  INFO
    Calling the custom action code for pre-install for payload {ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD} Adobe Photoshop CS6 Core_13.0.1_AdobePhotoshop13-Core 13.0.1.0
    ::START TIMER:: [Payload Operation :{ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD}]
    [       1] Mon Sep  3 12:48:42 2012  INFO
    Payload {ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD} Adobe Photoshop CS6 Core_13.0.1_AdobePhotoshop13-Core 13.0.1.0: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE6/resources
    [       1] Mon Sep  3 12:48:43 2012  INFO
    Beginning installation for payload at /private/tmp/.tempdirxrt8Ehor/Install.db
    Attempting to patch file: "/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Resources/Adobe Photoshop CS6.rsrc"(Seq 7)
    [       1] Mon Sep  3 12:48:44 2012  INFO
    Attempting to patch file: "/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/required/Ado be Crash Reporter.app/Contents/Resources/es.lproj/Localizable.strings"(Seq 9)
    Attempting to patch file: "/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/required/Ado be Crash Reporter.app/Contents/Resources/it.lproj/InfoPlist.strings"(Seq 11)
    Attempting to patch file: "/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Import-Export/EazelAcquire.plugin/ Contents/Info.plist"(Seq 13)
    Attempting to patch file: "/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO"(Seq 15)
    Attempting to patch file: "/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Image Stacks/statistics.plugin/Contents/MacOS/statistics"(Seq 17)
    Attempting to patch file: "/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Digimarc/DigiSign.plugin/Contents/ MacOS/DigiSign"(Seq 19)
    [       1] Mon Sep  3 12:48:44 2012 ERROR
    DW063: Command ARKPatchCommand failed.(Seq 19)
    Completing installation for payload at /private/tmp/.tempdirxrt8Ehor/Install.db
    [       0] Mon Sep  3 12:48:44 2012  INFO
    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
    :: END TIMER :: [Payload Operation :{ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD}] took 2727 milliseconds (2.727 seconds) DTR = 5886.32 KBPS (5.74836 MBPS)
    The csu inventory was not updated for payload {ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD} Adobe Photoshop CS6 Core_13.0.1_AdobePhotoshop13-Core 13.0.1.0, value of local var is -1
    Calling the ROLLBACK custom action code for pre-install for payload {ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD} Adobe Photoshop CS6 Core_13.0.1_AdobePhotoshop13-Core 13.0.1.0
    [       0] Mon Sep  3 12:48:45 2012  INFO
    No operation.  We're done:
    [       0] Mon Sep  3 12:48:47 2012  INFO
    Successfully installed 1 component:
    - Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support
    Total components repaired: 0
    Total components removed: 0
    [       0] Mon Sep  3 12:48:47 2012 ERROR
    DW050: The following payload errors were found during install:
    DW050:  - Adobe Photoshop CS6 Core_13.0.1_AdobePhotoshop13-Core: Install failed
    Call PostSession Custom Hook
    :: END TIMER :: [Total Timer] took 26201 milliseconds (26.201 seconds) DTR = 2049.54 KBPS (2.0015 MBPS)
    -------------------------------------- Summary --------------------------------------
    - 0 fatal error(s), 28 error(s), 0 warning(s)
    ERROR: DW023: The extension payload: {05F4F74F-F432-41A5-8C0F-D0CE27DF43A6} Adobe Photoshop CS6 Russian Language Pack_13.0.1_AdobePhotoshop13-ru_RU 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {0C0D5FFE-5163-4C31-99A8-67E101BFE989} Adobe Photoshop CS6 Czech Language Pack_13.0.1_AdobePhotoshop13-cs_CZ 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {199CF0F4-7D40-4040-971D-D4DC22FAD746} Adobe Photoshop CS6 Ukrainian Language Pack_13.0.1_AdobePhotoshop13-uk_UA 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {22B297EF-8769-4482-BC5C-23FA225E4D22} Adobe Photoshop CS6 Swedish Language Pack_13.0.1_AdobePhotoshop13-sv_SE 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {2AD0D397-31E7-4702-921A-3D0457CDA9F0} Adobe Photoshop CS6 Chinese Language Pack_13.0.1_AdobePhotoshop13-zh_CN 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {52311082-D399-4BC8-91B8-EE90D7DD3797} Adobe Photoshop CS6 IL English Language Pack_13.0.1_AdobePhotoshop13-en_IL 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {686EDFB9-5454-47D4-9272-182A4D7A447C} Adobe Photoshop CS6 AE English Language Pack_13.0.1_AdobePhotoshop13-en_AE 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {6A166824-93B4-483B-B719-38603EC354EE} Adobe Photoshop CS6 Hungarian Language Pack_13.0.1_AdobePhotoshop13-hu_HU 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {6F660A0B-5C68-476C-8829-D922B03B5124} Adobe Photoshop CS6 Brazilian Portugese Language Pack_13.0.1_AdobePhotoshop13-pt_BR 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {76B845AC-61A5-4A2A-8B2B-E8C0A2C5C461} Adobe Photoshop CS6 Spanish Language Pack_13.0.1_AdobePhotoshop13-es_ES 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {79254C4B-C13F-47A0-A9C9-914A9A2C167A} Adobe Photoshop CS6 Italian Language Pack_13.0.1_AdobePhotoshop13-it_IT 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {7F5EF61F-3FD6-4710-9289-A9FAD5CBBA1D} Adobe Photoshop CS6 Finnish Language Pack_13.0.1_AdobePhotoshop13-fi_FI 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {9F58F6CE-D903-4AA6-9812-5748390B9643} Adobe Photoshop CS6 Danish Language Pack_13.0.1_AdobePhotoshop13-da_DK 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {A16E2190-73DD-4823-89AB-224F2AF89690} Adobe Photoshop CS6 French Language Pack_13.0.1_AdobePhotoshop13-fr_FR 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {A41B2BD4-0697-4267-8D8A-A83B5DAD08B4} Adobe Photoshop CS6 Chinese (traditional) Language Pack_13.0.1_AdobePhotoshop13-zh_TW 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {B040AE9B-41F3-4AA1-89C5-C29003C87389} Adobe Photoshop CS6 International English Language Pack_13.0.1_AdobePhotoshop13-en_GB 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {B16E4780-1569-464F-8405-D4BF620E0373} Adobe Photoshop CS6 Turkish Language Pack_13.0.1_AdobePhotoshop13-tr_TR 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {C3411DF1-0D93-4437-9233-05FFCBC789F4} Adobe Photoshop CS6 North American Spanish Language Pack_13.0.1_AdobePhotoshop13-es_MX 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {D8560CFF-756D-4259-A42A-0C9C41D6D638} Adobe Photoshop CS6 Japanese Language Pack_13.0.1_AdobePhotoshop13-ja_JP 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {DBD9DF05-1D69-4F31-9154-927F9F808013} Adobe Photoshop CS6 Dutch Language Pack_13.0.1_AdobePhotoshop13-nl_NL 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {DE32ABBD-DEB4-45A8-958E-0C574655BE58} Adobe Photoshop CS6 Norwegian Language Pack_13.0.1_AdobePhotoshop13-nb_NO 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {E5D5D587-B139-4251-8B6C-0FF28927F9D1} Adobe Photoshop CS6 Polish Language Pack_13.0.1_AdobePhotoshop13-pl_PL 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {E848088E-1919-4BE4-9D2E-B168EDA8CF49} Adobe Photoshop CS6 Korean Language Pack_13.0.1_AdobePhotoshop13-ko_KR 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {E92B626B-A0D8-4DCA-A1C9-E474FBD969AE} Adobe Photoshop CS6 MA French Language Pack_13.0.1_AdobePhotoshop13-fr_MA 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {FA65AB82-B627-442B-B2D0-991CEB0EA1B4} Adobe Photoshop CS6 Canadian French Language Pack_13.0.1_AdobePhotoshop13-fr_CA 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ERROR: DW023: The extension payload: {FB5A3F35-F507-4FD4-956C-505CFA446FEB} Adobe Photoshop CS6 German Language Pack_13.0.1_AdobePhotoshop13-de_DE 13.0.1.0 requires a parent with following specification:
              Family: Photoshop
              MinVersion: 0.0.0.0
    ----------- Payload: {ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD} Adobe Photoshop CS6 Core_13.0.1_AdobePhotoshop13-Core 13.0.1.0 -----------
    ERROR: DW063: Command ARKPatchCommand failed.(Seq 19)
    ERROR: DW050: The following payload errors were found during install:
    ERROR: DW050:  - Adobe Photoshop CS6 Core_13.0.1_AdobePhotoshop13-Core: Install failed
    Please search the above error/warning string(s) to find when the error occurred.
    These errors resulted in installer Exit Code mentioned below.
    [       0] Mon Sep  3 12:48:48 2012  INFO
    Exit Code: 6 - Silent workflow completed with errors.
    Please see specific errors and warnings for troubleshooting. For example, ERROR: DW023, DW063 ...
    END - Installer Session
    OSX version: 10.7.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 53 milliseconds (0.053 seconds) DTR = 75.4717 KBPS (0.0737028 MBPS)
    Updated source path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6
      Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CS6
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-ru_RU-130812102134/AdobePhotoshop13-ru_ RU-130812102134.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-cs_CZ-130812101708/AdobePhotoshop13-cs_ CZ-130812101708.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-uk_UA-130812102303/AdobePhotoshop13-uk_ UA-130812102303.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-sv_SE-130812101243/AdobePhotoshop13-sv_ SE-130812101243.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-zh_CN-130812095757/AdobePhotoshop13-zh_ CN-130812095757.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-en_IL-130812102727/AdobePhotoshop13-en_ IL-130812102727.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-Support-130812103612/AdobePhotoshop13-S upport-130812103612.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-en_AE-130812102559/AdobePhotoshop13-en_ AE-130812102559.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-hu_HU-130812102431/AdobePhotoshop13-hu_ HU-130812102431.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-pt_BR-130812100053/AdobePhotoshop13-pt_ BR-130812100053.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-es_ES-130812101115/AdobePhotoshop13-es_ ES-130812101115.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-it_IT-130812100351/AdobePhotoshop13-it_ IT-130812100351.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-fi_FI-130812101411/AdobePhotoshop13-fi_ FI-130812101411.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-da_DK-130812100222/AdobePhotoshop13-da_ DK-130812100222.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-fr_FR-130812100648/AdobePhotoshop13-fr_ FR-130812100648.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-zh_TW-130812095629/AdobePhotoshop13-zh_ TW-130812095629.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-en_GB-130812095201/AdobePhotoshop13-en_ GB-130812095201.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-tr_TR-130812102006/AdobePhotoshop13-tr_ TR-130812102006.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-es_MX-130812100946/AdobePhotoshop13-es_ MX-130812100946.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-ja_JP-130812095332/AdobePhotoshop13-ja_ JP-130812095332.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-nl_NL-130812100520/AdobePhotoshop13-nl_ NL-130812100520.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-nb_NO-130812101540/AdobePhotoshop13-nb_ NO-130812101540.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-pl_PL-130812101837/AdobePhotoshop13-pl_ PL-130812101837.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-ko_KR-130812095502/AdobePhotoshop13-ko_ KR-130812095502.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-fr_MA-130812102854/AdobePhotoshop13-fr_ MA-130812102854.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-Core-130812103054/AdobePhotoshop13-Core -130812103054.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-fr_CA-130812100817/AdobePhotoshop13-fr_ CA-130812100817.dmg
      Path: /Volumes/Adobe Photoshop CS6/Adobe Photoshop CS6/payloads/AdobePhotoshop13-de_DE-130812095924/AdobePhotoshop13-de_ DE-130812095924.dmg
    [       0] Mon Sep  3 12:53:42 2012  INFO
    [       0] Mon Sep  3 12:53:42 2012 ERROR
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
    Overwrite property "DEVersion" to: 6.0
    Value returned on lookup of payload: {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0 is: true
      {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0:  with operation repair
    [       0] Mon Sep  3 12:53:42 2012  WARN
    DW035: Patcher: {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0 has already been applied. Patchers cannot be repaired/reinstalled, skipping this patcher
    [       1] Mon Sep  3 12:53:42 2012  INFO
    [       1] Mon Sep  3 12:53:43 2012  INFO
    [       1] Mon Sep  3 12:53:44 2012  INFO
    Beginning installation for payload at /private/tmp/.tempdirZlEiRcrt/Install.db
    [       1] Mon Sep  3 12:53:45 2012  INFO
    [       1] Mon Sep  3 12:53:45 2012 ERROR
    Completing installation for payload at /private/tmp/.tempdirZlEiRcrt/Install.db
    [       0] Mon Sep  3 12:53:45 2012  INFO
    :: END TIMER :: [Payload Operation :{ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD}] took 2518 milliseconds (2.518 seconds) DTR = 308.181 KBPS (0.300958 MBPS)
    [       0] Mon Sep  3 12:53:45 2012  WARN
    Skipping payload {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0 as payload is not cached
    [       0] Mon Sep  3 12:53:55 2012  INFO
    [       0] Mon Sep  3 12:53:57 2012  INFO
    Total components installed: 0
    [       0] Mon Sep  3 12:53:57 2012 ERROR
    DW050:  - Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support: Patch already installed
    :: END TIMER :: [Total Timer] took 18747 milliseconds (18.747 seconds) DTR = 498.213 KBPS (0.486536 MBPS)
    - 0 fatal error(s), 29 error(s), 2 warning(s)
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
    WARNING: DW035: Patcher: {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0 has already been applied. Patchers cannot be repaired/reinstalled, skipping this patcher
    ERROR: DW050:  - Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support: Patch already installed
    [       0] Mon Sep  3 12:53:58 2012  INFO
    Exit Code: 7 - Unable to complete Silent workflow.
    Please see specific errors and warnings for troubleshooting. For example, ERROR: DW023, DW063 ... WARNING: DW035 ...
    OSX version: 10.7.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 574 milliseconds (0.574 seconds) DTR = 48.7805 KBPS (0.0476372 MBPS)
    [       0] Mon Sep  3 13:07:54 2012  INFO
    [       0] Mon Sep  3 13:07:54 2012 ERROR
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
    [       0] Mon Sep  3 13:07:58 2012  INFO
    [       0] Mon Sep  3 13:07:58 2012  WARN
    [       0] Mon Sep  3 13:07:59 2012  INFO
    [       1] Mon Sep  3 13:07:59 2012  INFO
    [       1] Mon Sep  3 13:08:00 2012  INFO
    Beginning installation for payload at /private/tmp/.tempdirGLxwS05H/Install.db
    [       1] Mon Sep  3 13:08:01 2012  INFO
    [       1] Mon Sep  3 13:08:02 2012  INFO
    [       1] Mon Sep  3 13:08:02 2012 ERROR
    Completing installation for payload at /private/tmp/.tempdirGLxwS05H/Install.db
    [       0] Mon Sep  3 13:08:02 2012  INFO
    :: END TIMER :: [Payload Operation :{ED027C6A-DE62-4BD2-BD00-3CF183A6BDAD}] took 3556 milliseconds (3.556 seconds) DTR = 2379.08 KBPS (2.32332 MBPS)
    [       0] Mon Sep  3 13:08:03 2012  WARN
    [       0] Mon Sep  3 13:08:03 2012  INFO
    [       0] Mon Sep  3 13:08:05 2012  INFO
    [       0] Mon Sep  3 13:08:05 2012 ERROR
    :: END TIMER :: [Total Timer] took 17062 milliseconds (17.062 seconds) DTR = 7235.49 KBPS (7.06591 MBPS)
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
              Family: Photoshop
              MinVersion: 0.0.0.0
    [       0] Mon Sep  3 13:08:06 2012  INFO
    Sep 5, 2012 2:47 PM   in reply to MeeShellTheNerd
    Hello MeeShellTheNerd, and all,
    Several users have reported a resolution after an uninstall, and reinstall of Photoshop CS6, then applying the update either through the updater (easiest), or manually. After the uninstall/reinstall the update installed perfectly.
    Give this a try please.
    Pete
    Dec 11, 2012 7:20 AM   in reply to Pete.Green
    Still Not Working on my Machine:
    Exit Code: 6
    Please see specific errors and warnings below for troubleshooting. For example,  ERROR: DF024, DW063 ... WARNING: DW016 ...
    - 0 fatal error(s), 4 error(s), 4 warning(s)
    WARNING: DW016: NOTE: Cannot set action to the payload {0256558F-A0FF-4FCF-99C2-96D2EE3201D9} Suite Shared Configuration CS6 3.0.0.0 as it is already upgraded by the payload {C346BBCF-A687-4500-BB19-EE9C2D6FF284} Suite Shared Configuration CS6 3.0.0.0
    ----------- Payload: {9124DF4E-617D-486B-A970-8FA632244F24} Adobe Photoshop CS6 Core 13.0.0.0 -----------
    ERROR: DF024: Unable to preserve original file at "/Applications/Adobe/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/AdobeCrashRe porter" (Seq 94)
    ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 94)
    ERROR: DW050:  - Adobe Photoshop CS6 English Language Pack_AdobePhotoshop13-en_US: Install failed
    ERROR: DW050:  - Adobe Photoshop CS6 Core: Failed due to Language Pack installation failure
