Flash Player 11.4 r402 has stopped working.
Aug 31, 2012 6:16 PM
I am running Firefox 15.0 on a Windows Vista 32-bit machine.  After downloading the latest version of Flash Player I get a message that says Adobe Flash Player 11.4 r402 has stopped working.  How do I fix this problem?
    Aug 31, 2012 6:18 PM   in reply to pfmckay1949
    [topic moved to Flash Player forum]
    Sep 2, 2012 8:24 AM   in reply to Pat Willener
    Hi I had the same problem and was told to
    Stop Trusteer Rapport if you have it running and the problem will go away.
    You can stop and start Rapport by following:
    Start menu -> All Programs -> Trusteer Rapport -> Stop Rapport
    Re-started my computer and the problem has now gone.
    x
    Sep 2, 2012 11:44 AM   in reply to mistique247
    Many thanks mistique, your solution worked for me.
    Sep 2, 2012 5:06 PM   in reply to mistique247
    Windows 7/64.
    It worked for me too.  I didn't even need to restart. I just closed FF, stopped Rapport, restarted FF and all was well again.
    I plan to contact Trustee Rapport about the issue.
    Sep 2, 2012 5:13 PM   in reply to pfmckay1949
    For whatever its worth, I have never used Trusteer Rapport.  What worked for me to fix this same issue was to uninstall Flash 11.4, reboot my laptop, then come here to the archive and download the last 11.3 release.  After that, everything was OK once again. See here: http://forums.adobe.com/message/4506372#4506372 and then here: http://helpx.adobe.com/flash-player/kb/archived-flash-player-versions. html
    Sep 2, 2012 6:20 PM   in reply to Reno Russell
    I just confirmed the problem with Trusteer. (I was impressed with the speed of their on-line chat service.) They are aware of the problem and are presently working on a fix. They will notify me by e-mail when the fix is available. For anyone using Trusteer Rapport who is experiencing this problem, I recommend contacing them to get on their notification list. In the interim, they recommended that I unistall Rapport. I'm actually just using WinPatrol to (temporarily) disable it from starting.
    Sep 3, 2012 7:17 AM   in reply to Reno Russell
    Great thank you let me know what Tristeer Rapport say as i have also uninstalled mine.
    Sep 3, 2012 12:11 PM   in reply to mistique247
    A Tier 3 Support Engineer from Trusteer provided the fix (Rapport version 1205.8).  It solved the problem for me.  Here is the link I was given to download this version:
    https://trusteer.exavault.com/share/view/exo-gvdm939m-6r11kbij
    I did have some issues installing the new version.  If you have unistalled Rapport already, I wouldn't think you would have to repeat my experience.  Here's what I went through:
    First I tried to install Rapport (1205.8) in my user account. The install program failed and said I must log in to an Admin account.  I logged out of my user account, logged in to my Admin account, and tried again.  This time it said I must uninstall on the other (user account) where Rapport was installed.  So I logged out of my Admin account and logged in to my user account, uninstalled Rapport (from Control Panel | Programs and Features), logged out of my user account, logged back into my Admin account, and then installed Rapport (1205.8).  Next I rebooted and logged in to my user account and tested Adobe Flash Player in Firefox (at http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html).  As I said, all was well then.
    Sep 3, 2012 12:44 PM   in reply to Reno Russell
    Hi
    All worked well for me with the link.
    First time tho it said not installed & to re-boot. After re-booting i tried again & it was installed.
    Everything now working.
    Thank you so much.
    Sep 3, 2012 12:49 PM   in reply to Reno Russell
    Hello Reno, worked for me too. Many thanks for your help. I think a "well done" to Trusteer too for the quick fix.
    Regards.
    Sep 4, 2012 3:12 AM   in reply to Reno Russell
    Hello,
    The problem was solved in our last update, that can be downloaded directly from http://download.trusteer.com/Gcur4Wtnu/RapportSetup.exe
    If any issues remain or reoccur you are welcome to contact us at http://www.trusteer.com/support/submit-ticket and we will assist you shortly.
    Sincerely,
    Trusteer technical support
    Sep 5, 2012 10:49 PM   in reply to TrusteerSupport
    what is Trusteer Rapport why should i download it is there no patch from adobe to fix the problem my firefox gets slow, and when i see the task manager i find several instances of flash player 11.4. r402 running after ending the task of this process the firefox again gains speed.
    do i need to download Trusteer Rapport to fix the problem or should i roll back to flash player 10
    Please help
  • Chris Campbell
    May 4, 2010
    Sep 5, 2012 10:50 PM   in reply to Nancy Andrews
    @Nancy - If you do not have Trusteer Rapport already on your system, there is no need to install it for Flash Player.  The problem here was a conflict with an older version of Rapport and Flash Player.
    Chris
    Sep 10, 2012 10:54 AM   in reply to Chris Campbell
    No - I've no "Trusteer Rapport" product on my system.
    I've had problems like many users after 11.3 and now after updating to 11.4 r402.
    It is an conflict with "protected mode".
    Setting "ProtectedMode=0" resolves the problem!
    System:
    Win Vista HP 32bit, all updates without iE/E 9
    FF 15.0.1
    Sep 16, 2012 9:26 PM   in reply to pfmckay1949
    I am having the identitical problem after upgrading to Firefox 15.0.1.  I have installed, uninstalled, and rebooted at least three times in the last couple of days.  Very frustrating.  I keep hoping that a fix will be posted that works.  I do not have, nor have I ever had 'Trusteer Rapport' installed on my computer.  This is a red herring.
    System:
    Win Vista HP 32 bit with all updates applied.  FF 15.0.1
    Sep 18, 2012 5:21 PM   in reply to ElbonianKS
    This looks like the solution for me, but I can't figure out which archived player is for Firefox and Windows Vista.  Can you help?
  • Chris Campbell
    May 4, 2010
    Sep 21, 2012 3:27 PM   in reply to jbakely
    For 10.3.183.23 you'll want the file
    \fp_10.3.183.23_archive\10.3.183.23\flashplayer10_3r183_23_win.exe
    files that end with _win.exe are for firefox and ones with _winax.exe are for Internet Explorer
