I am using windows 7 64bit system with 2.3ghz processer and 3gb ram and 270gb disk space available laptop
but i m facing problem with downloading reader,flashplayer and shockwave player
pls help to me to install the products
Could you tel us a littl emore about the issues you are facing?
Or try the following links:
The links wil automatically determine your operating system and guide you through the rest of the installation process. You'll probably need Admin rights to instal software.
Adobe creates its instal files in "C:\Program Data\Adobe" which is a secured file and the installer cannot access the files inside. When you get the error,
open the folder "C:\Program Data\"
right-click the "Adobe" folder, select "Properties"
in the "Security" tab, click "Advanced"
then in the "Owner" tab, click "Edit" and "Change owner to"
also check the option for "Replace owner on subcontainers and objects"
click "Apply" and return to the error message
click "Retry" in the error window
the installer will continue without error
There is also a registry add-on TakeOwnership that will add an option in the Windows7 right-click menu to do this automatically for any file or folder.
I came across the same problem installing Adobe Reader on Windows7 64bit. The online instal failed, so I did the full download. The full download installer completed a download process to create the instal files, but as soon as it began the actual instal process, an error message occured saying the installer could not access files from C:\Program Data\Adobe. I retried the installer under "Run as administrater" with the same error at the same point in the instal. When I checked, I found that it was a secured folder, so I changed the ownership options for the folder and contents and then installer was able to continue.
