Problem with text and numbers alignment
Sep 6, 2012 1:17 AM
i have problem to align the number and the text.. it separates the number from the actual sentence.. how can i fix this?
    Sep 6, 2012 1:35 AM   in reply to HannaKarina
    That may be a feature of the font.
    Just select the numbers and in the Character Panel »Set the baseline shift«.
    Sep 6, 2012 1:41 AM   in reply to HannaKarina
    Sep 6, 2012 1:55 AM   in reply to HannaKarina
    Sorry, I misunderstood your issue.
    What are your Photoshop > Preferences > Type settings and on which OS do you work and what is its language?
    Do you also work with arabic, hebrew, chinese etc. fonts?
    Sep 6, 2012 1:56 AM   in reply to HannaKarina
    Sep 6, 2012 2:07 AM   in reply to HannaKarina
    You could (as always in case of unexplainable Photoshop-behaviour) try trashing prefs by keeping command-alt-shift/ctrl-alt-shift pressed while starting Photoshop after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved and making a note of the Preferences you’ve changed.
    Other than that check out the thread linked to in post 6.
  • Noel Carboni
    Dec 23, 2006
    Sep 6, 2012 3:31 AM   in reply to HannaKarina
    You've reset your Photoshop preferences?  You didn't make that clear.  If not, do so.
    You've tried setting the text options ("East Asian").
    Seems like what's left are these things, in no particular order:
    • Scour your system for any bad fonts.
    • Reinstall Photoshop.
    • Reinstall your operating system.
    -Noel
    Sep 6, 2012 4:02 AM   in reply to HannaKarina
    You did what?
    Others users with similar problems might benefit from a description of what steps solved the problem for you.
