claudio.rosati
Big DataGrid and ItemRenderers
Sep 5, 2012 6:52 AM
Tags: #datagrid #itemrender #rowcount
I've a "big problem".
A data grid with more than 200 rows witch has a rowCount="{dataProvider.length + 1}". The rowcount is evaluated in this way to have the datagrid show all his content without scroll bars so that the only scroll bar is at window level.
The problem is that the datagrid can't figure out witch rows are visible or not and so it instantiates the itemrenderers for all the rows (I know that generally it istantiates just the "rowcount" rows visible): this brings to an enormus amount of itemrenderes istantiated witch freeze the application and generate instability.
Is there a way to change this beahviour ?
Jus a note, I'm still working on Flex 3.6, but I think I would have the same problem with the newest releases.
    Sep 5, 2012 1:43 PM   in reply to claudio.rosati
    If you set rowCount to the length of the dataProvider, it will definitely show all rows.  What did you expect it to do instead?
    Sep 6, 2012 9:04 AM   in reply to claudio.rosati
    You can set verticalScrollPolicy=”none” and size the DG to the size of the window.  Then add your own scrollbar on the window and have it control the verticalScrollPosition of the DG.
    Sep 6, 2012 9:48 AM   in reply to claudio.rosati
