Hey Peeps
I'm currently trying to set up a action to take a .svg generated in html5 to a print ready eps with a spot knifeline
So I'm running into 2 problems
First is that I need to lock a few items so when I run a select all there not selected, but the actions don't seems to record it.
Then next big problem is that when I import or create a names swatch the actions don't record it. Meaning when I run a batch it continually comes up with an error message of swatch not found.
I was thinking maybe there is a way of changing the default swatches so it is already there when the file opens, But I havn't been able to crack it
Help
Any thoughts or work arounds would be great!!!!
Not everything in the user interface is recordable in Actions. (Far from it, in fact.) So you have to try to devise workarounds.
For example, depending on the specifics of your situation, you may be able to work around the missing Swatch problem by having something already residing on the clipboard that is filled or stroked with that Swatch, and that is "tagged" with a piece of text in the Note field of the Attributes palette:
1. In a new document, create a Global Swatch, and give it a unique name (Ex: MyGlobalSwatch).
2. Draw a simple path (an ellipse or anything). Stroke of none, Fill of MyGlobalSwatch.
3. Select the path. In the Note field of the Attributes palette, type "TempObject".
4. Copy the object to the clipboard.
5. In your Action, after the step that opens the source file, include a Paste step. That will create the Swatch.
6. At the end of your Action, include a Select Object... step that selects an object by the Note "TempObject", followed by a Delete step.
As for locking objects that are contained in the source file, the objects of interest would have to have some attribute that is selectable by an Action and which distinguishes that/those object(s) from others. So...
1. Find something (a stroke weight, a stroke color, a fill color) that is unique to the objects in the source files that you want to lock, and that is consistent in all the incoming source files.
2. Use a temporary object on the clipboard as described above, to which you have applied that same attribute, and which you have tagged with a Note.
3. In the Action, similarly include steps to Paste the temporary object. Follow that with a step to invoke the appropriate Select Same... command. Then lock the selection.
Again, the possibilities depend on specifics of the objects involved. When you just can't devise an Action-based workaround, that's when you resort to scripting. After resorting to scripting is when you find out that the scripting model cannot access everything in the user interface, either. That's when you realize that alot of wonderful things could be done by combining Actions and Scripts for a given task. That's when you find out that Scripts can't call Actions, and although Actions can invoke Scripts, they don't do it reliably; the Action steps which invoke the scripts do not survive re-launches of the program. This bug has gone uncorrected for something like five or six full versions now.
JET
You can also record an action that opens a file whose only object uses the needed swatch, select all, and copy.
Once you have the file open that you want to do the action on, a simple paste and cut is all you need to have access to the swatch later in the action.
Beware of any steps to close the file that had the needed swatch, because it tens to crash the program.
