InDesign quits after network connection lost error
Sep 5, 2012 7:53 AM
Tags: #lost #crash #indesign #connection #network
InDesign all of a sudden is crashing with the following error:
"The network connection was lost for the file InDesign SavedData, or the file was modified by another process"
followed by:
Adobe InDesign is shutting down. A serious error was detected. Please restart InDesign to recover work in any unsaved InDesign documents." (button) "Return to Finder"
then:
"InDesign quit unexpectedly. Click Reopen to open application again. Click Report to see more detailed information and send a report to Apple."
Then I get the Adobe Crash Report.
Restarting InDesign gives the same results, both opening a file and opening the application directly.
I have trashed InDesign Preferences and tried throwing away the InDesign Recovery folder, but no change.
Specifics:
-InDesign CS5, ver 7.0.4.553
-iMac Core i7, OS 10.7.4
-I am not in a network environment—all InDesign documents are local.
-InDesign CS4 works okay.
Here is the the crash report:  http://pastebin.com/1ZvvSJCa
Any suggestions will be greatly appreciated!
Cliff
    Sep 5, 2012 8:32 AM   in reply to cmrusch
  • John Hawkinson
    Jun 25, 2009
    Sep 6, 2012 7:10 AM   in reply to cmrusch
    I tried all three solutions and InDesign still crashes with the same error messages.
    Your crash report indicates a protective shutdown:
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0   PublicLib.dylib                    0x011a3fc7 ProtectiveShutdown::~ProtectiveShutdown() + 279
    protective
    That means you should open ~/Library/Caches/Adobe InDesign/Version 7.0/en_us/InDesign Recovery/Protective Shutdown Log and see what it reports (you can also upload it to http://pastebin.com/) for more information.
    Any thoughts or suggestions? I need to get things working again as I have client projects pending.
    Quick tip is to create a new user account and see if the problem goes away.
    Did you try Trash, Replace, Reset, or Restore the application Preferences?
    Sep 6, 2012 7:24 AM   in reply to John Hawkinson
    John,
    It's so nice to see you back here helping with these. You definitely were missed.
  • John Hawkinson
    Jun 25, 2009
    Sep 6, 2012 7:56 AM   in reply to Peter Spier
    Yeah, sorry, life's been busy! Trying to get back in...
    Sep 6, 2012 8:00 AM   in reply to John Hawkinson
    Didn't you read the fine print when you signed up? You no longer get to have a life.
  • John Hawkinson
    Jun 25, 2009
    Sep 6, 2012 8:15 AM   in reply to cmrusch
    Here is the link to the protective shutdown log:
    http://pastebin.com/iMeb4Uph
    Oh, hrmm; it's got lots of:
    Adobe InDesign Protective Shutdown Log
    Thu Sep  6 06:56:54 2012
    Lost network connection of open database
    Session started up at 6:56 AM on Thu, Sep 6, 2012
    Version: 7.0.4 - Build: 553
    No Error Info
    And, hrmm. We've sort of seen that before. But I don't think it means what it looks like it means...
    p.s.: Peter, I still have...a lot of catching up to do....
    Sep 6, 2012 8:21 AM   in reply to John Hawkinson
    I noticed a few Load Failed lines, but I don't know what that means...
