InDesign all of a sudden is crashing with the following error:
"The network connection was lost for the file InDesign SavedData, or the file was modified by another process"
followed by:
Adobe InDesign is shutting down. A serious error was detected. Please restart InDesign to recover work in any unsaved InDesign documents." (button) "Return to Finder"
then:
"InDesign quit unexpectedly. Click Reopen to open application again. Click Report to see more detailed information and send a report to Apple."
Then I get the Adobe Crash Report.
Restarting InDesign gives the same results, both opening a file and opening the application directly.
I have trashed InDesign Preferences and tried throwing away the InDesign Recovery folder, but no change.
Specifics:
-InDesign CS5, ver 7.0.4.553
-iMac Core i7, OS 10.7.4
-I am not in a network environment—all InDesign documents are local.
-InDesign CS4 works okay.
Here is the the crash report: http://pastebin.com/1ZvvSJCa
Any suggestions will be greatly appreciated!
Cliff
I think it mightr be this: http://helpx.adobe.com/indesign/kb/indesign-crashes-blank-dialog-boxes .html
Thanks Peter,
I tried all three solutions and InDesign still crashes with the same error messages.
I also tried the recovery function of OS X Lion (http://support.apple.com/kb/HT4718). It automatically installed 10.7.4.
InDesign still crashes and now Safari crashes with a "Safari quit unexpectedly" error.
Any thoughts or suggestions? I need to get things working again as I have client projects pending.
Will Mountain Lion solve these issues?
Many thanks,
Cliff
Your crash report indicates a protective shutdown:
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 PublicLib.dylib 0x011a3fc7 ProtectiveShutdown::~ProtectiveShutdown() + 279
protective
That means you should open ~/Library/Caches/Adobe InDesign/Version 7.0/en_us/InDesign Recovery/Protective Shutdown Log and see what it reports (you can also upload it to http://pastebin.com/) for more information.
Quick tip is to create a new user account and see if the problem goes away.
Did you try Trash, Replace, Reset, or Restore the application Preferences?
Thank you John.
Here is the link to the protective shutdown log:
I had manually deleted the preferences yesterday, but just tried the Cmd + Ctrl + Opt + Shift route and that appears to have solved the problem! Apparently I didn't get everything on the manual delete.
A big Thank You! to you and Peter for the help. I appreciate it very much.
I will contact Apple r.e. the Safari problem as I still have Applecare.
Best,
Cliff
Oh, hrmm; it's got lots of:
Adobe InDesign Protective Shutdown Log
Thu Sep 6 06:56:54 2012
Lost network connection of open database
Session started up at 6:56 AM on Thu, Sep 6, 2012
Version: 7.0.4 - Build: 553
No Error Info
And, hrmm. We've sort of seen that before. But I don't think it means what it looks like it means...
p.s.: Peter, I still have...a lot of catching up to do....
