WiscoLori
Backwards Compatibility of RH 10 and RH 9
Sep 6, 2012 7:52 AM
Tags: #compatability #child #robohelp_9 #parent #merged_project #robohelp_10
We are authoring a new RH child project in RH10.  The RH parent project was authored by our business partner in RH9, therefore the style sheets, master pages, skins, etc. are also all in RH9.  Does anyone know of any backwards compatability issues with a RH10 child project working with a RH9 parent project?  Our child works as a merged project with the parent and other child projects.  Our child project will consist of HTML pages and some graphics but all style, layout, custom menus, and skins  will be inherited from the parent.  Thanks!
    Sep 6, 2012 7:57 AM   in reply to WiscoLori
    Check Captiv8r's recent posts - Rick was doing some testing with backwards compatibility for another thread, IIRC...
  • RoboColum(n)
    Oct 8, 2004
    Sep 6, 2012 8:32 AM   in reply to WiscoLori
    I have just created a topic complete with some content in RH10 and successfully imported it into a RH9 project. It even changed the <meta name="generator" content="Adobe RoboHelp 9" /> meta tag. Best to test this with your content though.
    Sep 6, 2012 8:37 AM   in reply to WiscoLori
    you mean Rick (aka Captiv8r), not me ;>)
    Oct 8, 2012 12:23 PM   in reply to WiscoLori
    See also the thread http://forums.adobe.com/message/4758551#4758551 for a solution. Note that not everything may work as expected.
    Greet,
    Willam
    Oct 12, 2012 7:15 AM   in reply to WiscoLori
    I would warn you about any RH9 project compiled in Windows 7. I upgraded to RH10 because the Search feature in RH9 broke as soon as they installed Windows 7. The upgrade fixed the search problems. However...
    When I began upgrading RH9 projects to RH10 I encountered bugs. The first one is that you cannot always delete baggage files that were in the RH9 project. You can only always delete baggage files that you add within RH10. I reported this one.
    I also had some issues with conditional tags - I tried to rename RH9/Windows 7 tags from within RH10, and they grayed out on me when I tried to apply them. I haven't reported that because I found a workaround and didn't have time.
    Also, the Table of Contents was fine if you published one project, but it totally disappeared in a parent project that had merged child  projects. It just wasn't there AT ALL. So the programmer and I worked on that one for hours, until it occurred to me to work with an archived version of the parent shell that I'd generated in Windows XP. That solved the TOC problem. I also haven't reported that, but just be forewarned.
    Oct 12, 2012 10:13 AM   in reply to WiscoLori
    I don't doubt that namedujour has had these problems but it does not seem to be common. It needs to be established whether the issues are RoboHelp or the project. The fact that they did not occur in earlier versions does not necessarily mean there are bugs in RoboHelp.
    @petergrainge
