      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
i need help please
Participant ,
Sep 03, 2012 Sep 03, 2012
hi , how are you guys ? i hope you all fine..
here
i have 2 problems the first one is why some sounds files  change after importing  it into flash
and how can i fix that
second problem is why flash asking me to add semicolon !! this is the first time and (i guess) it is because of static type , because i get this problem when i did that(trying to access variable from another class) also i couldn,t fix it after adding semicolon
here are the 2 classes
MAIN CLASS
package
import flash.display.MovieClip;
import flash.events.Event;
import flash.events.KeyboardEvent;
    import flash.ui.Keyboard;
   import flash.media.Sound;
        import flash.media.SoundChannel;
public class MAIN extends MovieClip
  var LINKCONVERT:linkconvert = new linkconvert
  var checkpoint:Boolean
var fireballindex:Array = new Array
var ele:int
var i:int = 0
var FIREBIRD:firebird = new firebird
var SCREAM:scream = new scream
var SOUNDCHANNEL:SoundChannel = new SoundChannel
  public function MAIN()
   addEventListener(Event.ADDED_TO_STAGE,onAddedToStage);
  public function onAddedToStage(event:Event):void
   addEventListener(Event.ENTER_FRAME,onEnterFrame);
    stage.addEventListener(KeyboardEvent.KEY_DOWN,onKeyDown);
    FIREBIRD.stop()
  public function onEnterFrame(event:Event)
FIREBIRD.x = hero.x
FIREBIRD.y = hero.y
if (hero.ELECTRICALSHIELD.stage){
healthbar1.width -=1
if (bat1h != null){
if (bat1h.stage){
  if (hero.hitTestObject(bat1)){
  bat1h.width -= 5
if (bat1 != null){
if ( bat1h != null){
  if (bat1h.width == 0){
   removeChild(bat1h)
      removeChild(bat1)
            removeChild(bat1b)
            bat1b = null
      bat1 = null
      bat1h = null
if (bat1 != null){
if (bat1.stage){
   healthbar1.width -=  5
   if (bat1 != null)
     healthbar1.width -=  1;
   if (healthbar1.width >= 80 && healthbar1.width <= 100)
    zelda1.gotoAndPlay(1);
   if (healthbar1.width >= 60 && healthbar1.width <= 80)
    zelda1.gotoAndPlay(2);
   if (healthbar1.width >= 40 && healthbar1.width <= 60)
    zelda1.gotoAndPlay(3);
   if (healthbar1.width >= 20 && healthbar1.width <= 40)
    zelda1.gotoAndPlay(4);
   if (healthbar1.width >= 0 && healthbar1.width <= 20)
    zelda1.gotoAndPlay(5);
   if (hero.hitTestObject(portal3))
    if (bat1 != null)
     var map4:BACKGROUND = new BACKGROUND  ;
     removeChild(bat1);
     bat1 = null;
     // this doesn't need to be done unless you added a listener outside the Bat1 classs
    }//normal
   }//normal
  }//func
   public function onKeyDown(event:KeyboardEvent):void {
            if (event.keyCode == Keyboard.E)
         if (hero.visible){
  if(checkpoint){
   SOUNDCHANNEL = SCREAM.play()
                                hero.visible = false
        addChild(FIREBIRD)
      if (!hero.visible){
if(FIREBIRD.stage){
  if(!checkpoint){
   if(HERO.marioflying == false){
  SOUNDCHANNEL = LINKCONVERT.play()
                                hero.visible = true
        removeChild(FIREBIRD)
      checkpoint = !checkpoint
} //if event...
   }//fun
}//class
}//pack
HERO CLASS
package
        import flash.sensors.Accelerometer;
        public class HERO extends MovieClip
var MARIOHASFALLEN:mariohasfallen = new mariohasfallen;
var static marioflying:Boolean = true;
var vy:int
var ROARING:roaring = new roaring
                var NIGHTJUNGLE:nightjungle = new nightjungle
var heromovesduringfirefly:Boolean
                var ELECTRICALSHIELD:electricalshield = new electricalshield;
                var fBall:fireball = new fireball();
var fBalla:fireball = new fireball();
  var fBallb:fireball = new fireball();
var fireshooting:Boolean = false
var lastpos:int
                var FIREBALLSOUND:fireballsound = new fireballsound
                var speed:int = 3;
                var dir:int;
                var ELECTRICITY:electricity = new electricity;
                var firespeed:int = 10
                var totalfirespeed = 0
                var i:int
                var fdir:int
                var fireballFlying:Boolean; // keep track of fireball
                public function HERO()
                        addEventListener(Event.ADDED_TO_STAGE, onAddedToStage);
                        addEventListener(Event.ENTER_FRAME, onEnterFrame);
                        stage.addEventListener(KeyboardEvent.KEY_DOWN, onKeyDown);
                        stage.addEventListener(KeyboardEvent.KEY_UP, onKeyUp);
                        gotoAndStop(4);
                public function onEnterFrame(event:Event):void
if(visible){
if(y <325){
  y += 10
  if(marioflying){
   SOUNDCHANNEL = MARIOHASFALLEN.play()
   marioflying = false
  if(y>=325){
  y = 325
  marioflying = true
if(fBall.width > 55){
fBall.width = 55
if(fBall.height > 55){
fBall.height = 55
y += vy
                        x += dir * speed
                        if (fBall.stage)
                                fBall.x += firespeed * fdir;
                                fBall.width += 0
                                fBall.height += 0
                                totalfirespeed += 1
                        if (totalfirespeed == 20)
                                if (fBall.stage)
                                        MovieClip(parent).removeChild(fBall);
                                        totalfirespeed = 0;
                                        // fireball done flying
fdir = dir
                                        fireballFlying = false;
          fireshooting = false;
                        if (event.keyCode == Keyboard.RIGHT)
                                gotoAndStop(2);
                                // is fireball flying?
                                if (fireballFlying == false)
                                         fdir = +1
                                dir = 1;
                                speed = 10
                                if (ELECTRICALSHIELD.stage)
                                        addChild(ELECTRICALSHIELD)
if(MovieClip(parent).FIREBIRD.stage){
speed =30
MovieClip(parent).FIREBIRD.gotoAndStop(2)
                        if (event.keyCode == Keyboard.LEFT)
                                gotoAndStop(1);
                                        fdir = -1
                                dir = -1;
                                speed = 10
MovieClip(parent).FIREBIRD.gotoAndStop(1)
speed =30
                        if (event.keyCode == Keyboard.UP)
                               if (MovieClip(parent).FIREBIRD.stage)
vy = -30
      if (event.keyCode == Keyboard.DOWN)
        vy = 30
                        if (event.keyCode == Keyboard.Q)
                                if(visible){
                                speed = 30;
                                addChild(ELECTRICALSHIELD);
                                SOUNDCHANNEL = ELECTRICITY.play()
                        if (event.keyCode == Keyboard.W)
                                // tell myself a fireball is shot
                                fireballFlying = true;
if(!fireshooting){
fireshooting = true
                                fBall.name = "fb" + String(i);
                                fBall.width = 25;
           fBall.height = 25;
                                fBall.x = x + 20
                                fBall.y = y + 10
                                fireballindex.push(fBall);
          if(this.visible == false){
         if (MovieClip(parent).FIREBIRD.stage){
         fBall.width += 30
         fBall.height += 30
        SOUNDCHANNEL = ROARING.play()
                                MovieClip(parent).addChild(fBall);
if(this.visible == true){
if (!MovieClip(parent).FIREBIRD.stage){
                                SOUNDCHANNEL = FIREBALLSOUND.play()
                                i++;
                                trace(i)
                                trace(fBall.name)
                public function onKeyUp(event:KeyboardEvent):void
                                        removeChild(ELECTRICALSHIELD);
                                        if (SOUNDCHANNEL != null)
                                                speed = 0;
                                        SOUNDCHANNEL = ELECTRICITY.play(1, 1)
                                speed = 0
                                gotoAndStop(3);
                                speed = 0
                                gotoAndStop(4);
                                if (ELECTRICALSHIELD.stage){
       vy = 0
       vy = 0
   //Ł„Ų§ Ų§Ł„Ł‡ Ų§Ł„Ų§ Ų§Ł„Ł„Ł‡
    // there is no god except 1 god
and here is the error message
C:\Users\Owner n\Desktop\project ā€«(4)ā€¬ ā€«ā€¬\HERO.as, Line 39 1086: Syntax error: expecting semicolon before marioflying.
thank you guys for all the help in all my threads
ActionScript
2.1K
LEGEND , Sep 04, 2012 Sep 04, 2012
How does yours...
     var static ...
look the same as...
     public static var ...
You need to indicate which is line 39 of the Hero class code.
Participant ,
Participant ,
i dnt understand your answer , it is very short??
No one is likely to want to try to figure out which line of your Hero code is line 39.  You need to help others to help you by indicating which line of your Hero code is line 39.
You should not put all of your file(s) code into your posting every time you post.  It is unnecessary and makes reading your posting more difficult.  Only include the code that is directly relevant to your problem.  In this case, a few lines around line 39 might be sufficient to start with.
Participant ,
ohh sorry
its here
the second variable in the hero class
Participant ,
i,ve donwatching the examples in your link and it looks correct for me ? but it is not
so ... where should i put it?
thank you for your replay
How does yours...
     var static ...
look the same as...
Participant ,
Sep 06, 2012 Sep 06, 2012
thank you for your help
You're welcome
I wont be able to help with your sound issue.  You should probably start a new posting for that.  It is recommended you keep one topic/problem per posting - it helps finding solutions easier for others.
