I have a CS Extension for InDesign CS5.5 (Extension Builder 1.5), and now (after installing CS6 but later uninstalling it -- that's another story) I'm seeing a lot of messages like this in my Eclipse console window:
[INFO] CSAWLib.CSLogger TypeConUtils.getAnyPossibleClassDefinitionFor() Failed to find any class definition for com.adobe.indesign::Array
Sometimes it's for the Array type, sometimes for File. There's a LOT of these messages showing up, and I would like to find what happened at snuff this out.
Any ideas? This seems directly related to my aborted attempt to get onto CS6, but I can't find anywhere in my own code that I could be calling into the named function.
Cheers,
- Rich
This is happening to me too. I'm a CS Extension Builder n00b. I just downloaded 2.0 today, and created an extension targeting Flash Pro CS6, using Flash Builder 4.6. I get lots of these warnings:
[INFO] CSAWLib.CSLogger TypeConUtils.getAnyPossibleClassDefinitionFor() Failed to find any class definition for com.adobe.flashpro::Array
But eventually, I get a similar error that prevents any further progress:
[ERROR] CSAWLib.CSLogger CSHostObject.hostGet() failed on elements - with msg: Failed to find any class definition for com.adobe.flashpro::SymbolInstance
I was just exploring down into a MovieClip timeline. I haven't changed any project settings since it was setup. Here's the code:
package
import com.adobe.csawlib.flashpro.FlashPro;
import com.adobe.flashpro.*;
public class ExportFlashPro
public static function run():void
var app:Flash = FlashPro.app;
var doc:Document = app.getDocumentDOM();
if( doc == null )
app.outputPanel.trace( "No document opened." );
return;
var timeline:Timeline = doc.getTimeline();
for( var f:int=0; f=timeline.frameCount; ++f )
for( var l:int=timeline.layerCount-1; l>=0; --l ) // Loop backwards, back to front.
var layer:Layer = timeline.layers[ l ] as Layer;
if( layer.layerType != "normal" )
continue;
if( layer.frameCount < f )
continue; // This layer doesn't go that far.
var frame:Frame = layer.frames[ f ] as Frame;
if( frame.elements )
var elementCount:int = frame.elements.length;
for( var e:int=elementCount-1; e>=0; --e ) // Loop backwards, back to front.
var element:Element = frame.elements[ e ];
}Hi everyone,
This is a known issue in the CSAW libraries. The warnings regarding the missing definition of Array can be safely ignored.
For other cases, such as trying to iterate through the elements in a frame in Flash, you can define an unused variable of that type to provide a definition to get around this problem. For example, in Shane's case, you can do this:
var unused:SymbolInstance = null;
This would trigger the relevant CSAW library to find the class definition of SymbolInstance, therefore any subsequent methods that use it will work fine as expected.
Hope that helps and sorry for any inconvenience caused.
Joe
Thanks Joe. Is this something new? My impression is that this began after I’d installed CS6 (which I have since uninstalled). If this is the case, how do I get (or get back) to a configuration that avoids these messages? These come in dozens when I run a debug session and really clog up my console window, not to mention the effect this has on performance.
- Rich
