Audio out of sync in premiere pro cs6 after capturing
Sep 5, 2012 8:27 AM
Tags: #out #audio #of #audio_video_synchronizing
Hi, some of my footages are out of audio sync after capturing.
I have an imac with 3.4 Ghz intel i7 processor, 16gig ram, ssd card  ( august 2012)
I have a sony hvr-z1 with tape.
Does anyone know how to solve this problem?
Thanks in advance for your help.
    Sep 5, 2012 12:23 PM   in reply to inef1
    Hi
    Captured using a USB cable or a firewire?
    did we import those videos in PP and then check with the audio and video.
    Could be a permission issue as well. A good troubleshooting step can be stop all the applications while the video is being captured.
    Hope it Helps
    Sep 5, 2012 4:08 PM   in reply to inef1
    Is the Audio and video out of sync if you play the raw files in Media Player?
    Eric
    ADK
    Sep 6, 2012 10:01 AM   in reply to inef1
    Go Into edit and then preferences in Premiere. Go down to Capture and check mark use Device Control Timecode. Then launch capture utility and see if that fixes it.
    Eric
    ADK
    Sep 6, 2012 10:43 AM   in reply to inef1
    Does that mean you already had a check on that option?
    Eric
    ADK
    Sep 7, 2012 1:37 PM   in reply to inef1
    Try Capturing a portion in I Movie and then import into Premiere. See if the audio and video are in Sync then.
    Eric
    ADK
    Jan 11, 2013 11:26 AM   in reply to ECBowen
    I have a similar problem and yes, the audio and video are fine when played in Media Player,
    but when I import the mpeg4 to Premiere they are out of sync.
    Jan 11, 2013 11:33 AM   in reply to RSA 777
    Premiere Pro doesn't capture to an MP4 file.
    Jan 11, 2013 11:48 AM   in reply to Jim Simon
    Hi Jim,
    It may not capture to mp4, but it imports mp4.
    My footage is an ancient VHS family video, about 60 minutes.
    It imported fine.
    I imported into QT and it is in sync. I am going to export and
    then import the result into PP when I return tonight.
    Jan 11, 2013 2:20 PM   in reply to RSA 777
    You may have better luck going back to the original VHS and using PP to capture to a DV file.
    Jan 11, 2013 2:39 PM   in reply to RSA 777
    How did you convert a VHS tape to mp4... what hardware and software?
    Go to http://www.grassvalley.com/products/converters for a digitising device that will create DV AVI
    Jan 11, 2013 10:05 PM   in reply to Jim Simon
    Sync issue solved. Exporting from QT was a mistake. Took forever and
    didn't work.
    Saving from QT was just a few minutes. Then when I imported into
    PP there was no sync issue.
    Rick
    Jan 11, 2013 10:09 PM   in reply to John T Smith
    Hi John,
    Captured tape with Scenalyzer. Edited avi in Avid Liquid. As I said, years ago. Imported
    edited avi in Squeze to create mp4.
    Rick
    Jan 26, 2013 8:07 AM   in reply to inef1
    I'm sorry to ask within this topic, but I am using a Sony HVR-Z1 as well and am having trouble capturing in CS6. It says that the capture device is offline.It seems that you had the same problem and I was wondering if you can tell me how you fixed that.
    Hope to hear from you!
    Lynn
    Jan 26, 2013 8:12 AM   in reply to bigvissie13
    Lynn dont double post.
    Jan 26, 2013 8:47 AM   in reply to bigvissie13
    Good morning Lynn,
    I doubt this will help, but whenever I have issues importing tapes, I try
    something else. I double check the software's manual because
    sometimes, even if I have done the same thing several times, I add
    or miss something. If that does not work I close the program and restart
    the computer and camcorder and try again ... with a different tape. If
    that doesn't work I use a different program. I use an old HP workstation
    I paid $99 for on Ebay that's running XP and I capture with Scenalyzer.
    Then I copy file to a USB drive and input to Premiere. Sorry, I figure the
    problem is me, not the hardware or software and it usually is me because
    when the next project comes along PP usally imports fine.
