primary text flow in master based on another master
Sep 6, 2012 11:15 AM
I have 2 master pages: master A and master B. Master B is based on master A (master A is applied to master B).
There is primary text flow on both master pages.
When I RE-apply master A to master B primary text flow on master B is gone.
And all text frames on document pages which master B is applied to are no longer marked as primary text flow.
Is this normal?
    Sep 6, 2012 11:31 AM   in reply to Mnietek
    I'm not understanding the way you're describing the situation.
    You say, "When I RE-apply master A to master B, primary text flow on master B is gone."
    What are you actually doing? You don't reapply a master to another master. You apply a master to the document pages. Or, you apply a different master to the document pages.
    Try to explain more clearly, or post a screen capture.
    Sep 6, 2012 12:24 PM   in reply to Mnietek
    I think the problem may be in your workflow. I work a lot with master pages, and I've never tried to "reset" a child master by dropping master A on master B.
    Why do you want to "reset" master B? What do you want to change on master B? Please be more explicit what it is you want to change. I think screen captures would help. You can use the camera icon in the edit box to attach a screen capture.
    Sep 6, 2012 5:15 PM   in reply to Steve Werner
    Steve is right , it seems the document specific and workflow related issue ,
    you have Master A applied on Master B then there is no need to re-apply it , changes in the Master A will be automatically updated in the Master B.
    BTW if you create a fresh new master page C and apply the Master A then does it work ?
    , also what if you apply the None Master first on the Master B and then apply the Master A , does this work ?
