Could not generate timestamp: handshake alert:  unrecognized_name using JRE 1.7.7
Sep 5, 2012 1:18 PM
Tags: #air #jre1.7 #unrecognized_name
I'm new to this so I could be making some mistakes, but I'm learning Fireworks and I'm using an example from Chapter 13 of the Classroom In A Book for CS5.  It creates an AIR application, but when I try to generate the application I get the following error.
In my searches I came across a Flash Builder Help question and answer that lead me to a Flex Bug and Issue Management System report (http://bugs.adobe.com/jira/browse/FB-33243) that suggest this is a bug that effects JRE 1.7.
It suggest the following work around:
Uncheck the Timestamp check box in Package settings wizard and click finish.Application is successfully exported to Signed AIR package.
OK, what? Does this Settings wizard exhist in Fireworks? Is there a workaroung?
If I go back to JRE 1.6 does it work?
Dan
  • Chris Campbell
    May 4, 2010
    Sep 5, 2012 10:10 PM   in reply to CCAC_Teacher
    Does Fireworks output/publish to .air files?  This sounds like an ADT certificate timestamp server issue.  How are you creating the .air file?
  • Chris Campbell
    May 4, 2010
    Sep 6, 2012 1:58 PM   in reply to CCAC_Teacher
    Hi Dan,
    Try going back to JRE 6.  I just talked with a coworker who ran into a very similar problem, reverting from 7 to 6 fixed it for him.  I'll investigate further.
    Chris
Bookmarked By (1)
