I took over a website and the site uses Dreamweaver Templates. I'm not too familiar with the way that Templates works. Anyway, the nav (links at bottom of website) need to be updated. I updated the secondary.dwt file within the Templates folder. I uploaded it, but it's not updating the pages on the website that use this template file. Please help!
Thank you Jon for the quick reply! I know this might be a stupid question, but how do I update the associated files? When I open them, I'm not allowed to edit the nav links at the bottom (from the Template).
I don't know if this has something to do with it, but one associated file says this: <html><!-- InstanceBegin template="/Templates/secondary.dwt" codeOutsideHTMLIsLocked="false" --><head>
When you update the template from within DW, you should get a dialog asking if you want to update all of the files that use the template. When you click "OK" everything is updated across the site.
If you updated the template outside of the defined site, it won't update anything and you may have a bit of work on your hands.
In DW, you should have a Files tab with a drop down menu. The drop down menu should have all of your defined sites. Choose the site you are working on and a list of the files in that site will appear. Choose the template and make your changes and it will ask if you want to update everything else.
If you don't automatically get a prompt to update pages when you save your template.dwt, go to Modify > Templates > Update Pages.
Check a few child pages to be sure the changes were applied.
If all is good, upload the child pages to server.
If all is not good, be sure you're editing the correct template. Go to Modify > Templates > Open attached Template.
Nancy O.
