Greystone77
Dreamweaver crashes when I exit
Sep 6, 2012 10:18 AM
I am trying the Dreamweaver version 6.0 and when I exit the application I get the following error.
Problem signature:
  Problem Event Name: APPCRASH
  Application Name: Dreamweaver.exe
  Application Version: 12.0.0.5808
  Application Timestamp: 4f7617ae
  Fault Module Name: AdobeOwl.dll
  Fault Module Version: 4.0.93.0
  Fault Module Timestamp: 4f346283
  Exception Code: c0000005
  Exception Offset: 0001157a
  OS Version: 6.1.7601.2.1.0.256.1
  Locale ID: 1033
  Additional Information 1: 0a9e
  Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
  Additional Information 3: 0a9e
  Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
I tried a few other applications and do not get this error.
I am running Windows 7 Pro fully updated.
Processor Intel Core 2 Quad CPU Q9450 2.66 ghz
Video Card ATI Radeon HD 3800 with fully updated drivers.
4GB Ram
I can't find any information on what Adobeowl is, or how to fix it.
Any help fixing this issue is appreciated.
Thank You
    Sep 6, 2012 4:51 PM   in reply to Greystone77
    This is a user-to-user forum; not an official support site.
    You might want to contact Technical support.
    http://helpx.adobe.com/contact/
    Good luck and keep us posted on your outcome.
    Nancy O.
    Sep 6, 2012 5:05 PM   in reply to Nancy O.
    I think the OP is using a CS6 Trial version. No Tech Support available for trials.
    Sep 6, 2012 5:36 PM   in reply to John Waller
    Ooops.
    Look at Dreamweaver FAQ under Crashes.... and Unexplained Problems
    http://forums.adobe.com/thread/429114
    Nancy O.
    Sep 7, 2012 3:21 PM   in reply to Nancy O.
    Hi I realize it's a user forum but I was hoping someone else has had a similar problem or that someone may not what that module does.
    Thanks for the link though.
    Sep 8, 2012 12:34 PM   in reply to James Greystone
    I have the solution after trial and error to find a program on my system that was causing this problem and then searching the forums here to see if it affected anybody else.
    It seems that a program called Teamviewer ( a remote access software) if it is running or in the taskbar causes Dreamweaver to crash. The solution is to make a change to how Teamviewer runs.
    Here is a link to the adobe forum where the answer is discussed. Although it is not the exact same error message when it crashes the solution allows Dreamweaver to close normally.
    http://forums.adobe.com/message/4131161
    Thanks for the help everyone.
    Sep 8, 2012 1:37 PM   in reply to James Greystone
    Really glad you got this sorted and took time to share your solution.
    Nancy O.
