Timppa917
Flash player stops working after restart
Mar 27, 2012 12:42 AM
Tags: #help #install #windows #flash_player #installation #64bit #flashplayer #flash_player_11
Every time I restart my computer flash player just stops working. It juts looks like I would have no flash player installed at all and I will have to re-install. Very annoying.
Once I reinstall, everything works just fine until I restart my computer.
I have 64 bit Windows 7 if that helps at all.
    Mar 27, 2012 8:35 PM   in reply to Timppa917
  • Xircal
    Mar 29, 2011
    Mar 28, 2012 10:16 AM   in reply to Timppa917
    Try running this Microsoft Fixit tool: http://support.microsoft.com/mats/Program_Install_and_Uninstall
    After you run it, please do the following.
    1. Disable your antivirus application. Most modern security apps of this nature incorporate file scanners which spring into action to check for viruses as soon as the user attempts to install or uninstall a program. While this is a good thing when installing unknown apps, you should disable your AV when installing legitimate applications like Flash Player to prevent the AV file scanner interfering with the installation. If you have AVAST antivirus, right click the orange icon in systray, go to "AVAST shields control" and choose to disable all shields for one hour. If you have a different AV, consult this list for info on how to disable it: http://www.bleepingcomputer.com/forums/topic114351.html
    2. Next, download the Flash uninstaller. You don't say whether you're running a 64-bit browser of a 32-bit version, so here are both: Flash Player uninstaller 64-bit  Flash Player uninstaller 32-bit Even if you don't think Flash is installed, please run the appropriate uninstaller after you download it to your own machine. This means that when you see the IE prompt, choose "Save" and save the file somewhere where you can find it again easily. Do not choose "Run" even though that's an option.
    3. Next, close Internet Explorer, then go to the location you saved the uninstaller to and then double click it to uninstall Flash.
    4. Next, go here and download the full installer: http://helpx.adobe.com/flash-player/kb/installation-problems-flash-pla yer-windows.html#Install_in_a_firewall_proxy_server_environment You have to choose whether you need the 64-bit installer or the 32-bit version, but in any event, if you're using Internet Explorer, you must choose the "ActiveX" version. If you're not sure whether it's a 64-bit version or not, click the blue question mark and go to "About Internet Explorer". If you don't see "64-bit" anywhere, then you have the 32-bit version.
    5. When the download initiates, choose "Run" to install it immediately.
    6. Re-enable your antivirus and then reboot. Flash should remain accessible in IE.
    Mar 30, 2012 7:50 AM   in reply to Timppa917
    I'm running into the same issue with one computer on my network, also running Windows 7 x64 SP1.  A complete uninstall using the Adobe Uninstaller, then a full re-install, does not fix the issue - after rebooting, Flash stops working in both IE and Firefox.
    I should note that I am not getting any errors during installation, or uninstallation.  Everything seems to run smoothly, and Flash works fine... until you reboot.  At that point, both IE 9 and FF 11 act as if the Flash add-on is not installed.
  • Xircal
    Mar 29, 2011
    Mar 30, 2012 10:57 AM   in reply to GJSchaller
    Open Firefox and in the address bar, type: about:plugins Do you not see Shockwave Flash as shown in the screenshot?
    Apr 2, 2012 4:46 AM   in reply to Xircal
    Apr 9, 2012 8:07 AM   in reply to Xircal
    Sorry this took so long to reply - because it works until he reboots, he opted not to reboot for a week, so he could get work done.  I have exclusive access to his PC now, so I can work on this.
    Within Firefox 11.0, when I type about:plugins, I see the following:
    However, when I go to a page that contains Flash (such as https://www.adobe.com/software/flash/about/), the content does not load.
    The problem is persisting in IE as well, and Flash content will not load.  When I look in IE's add-ons, I see the following:
    This is after multiple attempts to uninstall (using the Adobe uninstaller tool), reinstalling using the full downloads, and running the MS FixIt tool linked above.  I've also made it a point to disable anti-virus, and also go through all the steps on this support page.
    Apr 9, 2012 8:14 AM   in reply to GJSchaller
    The problem appears somehow connected to specific user accounts - if I am logged in as a domain member, I cannot use Flash in either browser.  If I'm logged in as a Local Admin, I do not have the issue.
    No one else on the domain is having this issue, so it should not be an issue with our Domain Policy, as set.  It may be local to this PC, I am looking into a GPO refresh at the moment.
    Apr 9, 2012 8:36 AM   in reply to GJSchaller
    When I look in IE under "View and manage your Internet Explorer add-ons" I see the following:
    Name:                   Shockwave Flash Object
    Publisher:              Not Available
    Type:                   ActiveX Control
    Version:                0.0.0.1
    File date:
    Date last accessed:     ‎Today, ‎April ‎09, ‎2012, ‏‎1 minute ago
    Class ID:               {D27CDB6E-AE6D-11CF-96B8-444553540000}
    Use count:              38
    Block count:            34
    File:                   Flash32_11_2_202_228.ocx
    Folder:                 C:\Windows\SysWOW64\Macromed\Flash
    Apr 9, 2012 8:44 AM   in reply to GJSchaller
    When I re-install it, I see this:
    Publisher:              Adobe Systems Incorporated
    Version:                0.0.0.1
    File date:
    Date last accessed:     ‎Today, ‎April ‎09, ‎2012, ‏‎11:41 AM
    Use count:              57
    Block count:            37
    When I log out, and log back in as the same domain user (not even rebooting), the above data goes back to the "Publisher: Not Available" as seen above.
    This isn't just rebooting, this is something tied to the login / user using Windows.
    Apr 9, 2012 9:18 AM   in reply to GJSchaller
    Deleteing the user's profile and recreating it does NOT resolve the issue - when the new profile is created, the same issue is still there.
    The only difference between this computer, and the other 12 like it on the same network, is that this one has an ATI FirePro 2640 video card (for 4 monitors) instead of the standard ATI card (for two).
    Are there any known conflicts between Flash, and ATI's video drivers or software?
    Message was edited by: GJSchaller
  • Chris Campbell
    May 4, 2010
    Apr 9, 2012 12:16 PM   in reply to GJSchaller
    Can you please try the steps outlined here to see if this resolves the problem:
    1. Install Flash Player
    2. Download the SubInACL Installer from Microsoft
    3. Install SubInACL and note the install location
    4. Download the attached "reset_fp11.bat.zip" file and extract it to the SubInACL folder from the previous step.  At this point, subinacl.exe and reset_fp11.bat will be in the same folder.  Please note that you might not see the file extensions unless you've made them visible.
    5. If you are on Vista or Windows 7, right click "reset_fp11.bat" and select "Run as Administrator".  If you are on XP, please make sure you are using an Administrator level account before double clicking.
    6. You'll see a window appear and text go by, this should only take a few seconds to complete.  Once done, restart your computer and verify that Flash is working correctly.
    Chris
    Apr 9, 2012 1:00 PM   in reply to Chris Campbell
    That fixed it - thank you, VERY much!
    Jun 12, 2012 6:57 AM   in reply to Timppa917
    I tried all the suggestions in these posts, but none of them worked.  Assuming that  you only recently updated Adobe Flash Player,  just restore your system to the day before the update was installed.  Worked like a charm for me!
    Sep 3, 2012 11:17 AM   in reply to i did it my way
    From the looks of the number of comments all over the internet regarding this problem, there are thousands of computer users suffering this issue.
    I hope this problem gets fixed in the next release of Flash Player so that it doesn't take the expertese of an IT expert to correct it, and soon.  This is not the only major problem in the latest release.  Adobe, you've done better.
    Sep 4, 2012 9:35 AM   in reply to darkin99
    I performed the above six step routine and it fixed Flash for Internet Explorer but not for Firefox (my prefered  browser).
    I am running Windows 7 Home premium, SP1
    64Bit OS
    Firefox 14.0.1
    IE 9.0.8112.16421
    While running reset_fp11.bat I get repeated 'subinacl' is not recognized as an internal or external command
    Further help resolving the problem with Firefox would be appreciated.
  • Chris Campbell
    May 4, 2010
    Sep 4, 2012 3:45 PM   in reply to darkin99
    For Firefox, you might want to consider resetting your profile.  This has helped many strange situations in the past.
    http://support.mozilla.org/en-US/kb/reset-firefox-easily-fix-most-prob lems
    Sep 5, 2012 2:21 PM   in reply to Chris Campbell
    Chris – I tried resetting Firefox and it did not resolve the problem so I tried uninstalling Firefox and re-installing it.  That didn’t help either.  I still lose Flash when I reboot.
    Do you have a fix for Firefox similar to reset_fpll.bat above?
  • Chris Campbell
    May 4, 2010
    Sep 5, 2012 10:03 PM   in reply to darkin99
    No, nothing like that for Firefox.  Can you list out the files in your c:\windows\syswow64\macromed\flash folder the next time this occurs?
    Sep 6, 2012 12:44 PM   in reply to Chris Campbell
    Below are screenshots of before and after rebooting.  Flash worked fine with Firefox after reinstalling.  Flash would not work with Firefox after rebooting the computer.  Flash works fine with Internet Explorer in both instances.
    Index of file:///c:/windows/syswow64/macromed/flash/
    Up to higher level directory
    Flash32_11_4_402_265.ocx
    9414 KB
    9/5/2012
    5:56:38 PM
    1. FlashInstall.log
    111 KB
    8/14/2012
    10:16:00 PM
    FlashPlayerPlugin_11_4_402_265.exe
    1766 KB
    9/6/2012
    1:47:29 PM
    1. FlashPlayerUpdateService.exe
    245 KB
    9/6/2012
    1:47:29 PM
    FlashUtil32_11_4_402_265_ActiveX.dll
    464 KB
    9/5/2012
    5:56:38 PM
    FlashUtil32_11_4_402_265_ActiveX.exe
    675 KB
    9/5/2012
    5:56:38 PM
    FlashUtil32_11_4_402_265_Plugin.exe
    675 KB
    9/6/2012
    1:47:28 PM
    NPSWF32_11_4_402_265.dll
    9584 KB
    9/6/2012
    1:47:28 PM
    1. flashplayer.xpt
    1 KB
    9/6/2012
    1:47:29 PM
    1. install.log
    2 KB
    10/4/2010
    7:40:18 PM
    1. mms.cfg
    1 KB
    4/4/2012
    11:43:22 AM
    After reinstalling Flash.  Flash works fine with Firefox and Internet Explorer.
    9414 KB
    9/5/2012
    5:56:38 PM
    1. FlashInstall.log
    111 KB
    8/14/2012
    10:16:00 PM
    1766 KB
    9/6/2012
    1:47:29 PM
    245 KB
    9/6/2012
    1:47:29 PM
    464 KB
    9/5/2012
    5:56:38 PM
    675 KB
    9/5/2012
    5:56:38 PM
    675 KB
    9/6/2012
    1:47:28 PM
    9584 KB
    9/6/2012
    1:47:28 PM
    1. flashplayer.xpt
    1 KB
    9/6/2012
    1:47:29 PM
    1. install.log
    2 KB
    10/4/2010
    7:40:18 PM
    1. mms.cfg
    1 KB
    4/4/2012
    11:43:22 AM
      After rebooting.  Flash no longer works with Firefox
    Sep 6, 2012 1:01 PM   in reply to darkin99
    Please stop sending me emails.  Thanks.
  • Chris Campbell
    May 4, 2010
    Sep 6, 2012 1:48 PM   in reply to darkin99
    @darkin99 - Thanks.  The files looks the same before and after, so no worries about anything uninstalling Flash Player.  If you go to "about:plugins" in Firefox's address bar after rebooting, do you see Shockwave Flash (or anything else) listed?
    @i did it my way - To opt out of emails, visit the forum link and click "Stop email notifications" in the top right of the page.
    Sep 6, 2012 6:23 PM   in reply to Chris Campbell
    Chris:
    I see a long list of plugins including:
    Shockwave Flash
      File: NPSWF32_11_4_402_265.dll
      Version: 11.4.402.265
      Shockwave Flash 11.4 r402
          MIME Type Description Suffixes
          application/x-shockwave-flash Adobe Flash movie swf
          application/futuresplash FutureSplash movie spl
    And:
    Shockwave for Director
      File: np32dsw.dll
      Version: 11.5.7.609
      Adobe Shockwave for Director Netscape plug-in, version 11.5
          application/x-director Shockwave Movie dir,dxr,dcr
  • Chris Campbell
    May 4, 2010
    Sep 11, 2012 12:42 PM   in reply to darkin99
    Ok, well it appears that Flash Player is being loaded after reboot, so that's good.  Do you have any browser add-ons being loaded?  Could you try starting Firefox in safe mode (Help menu->Restart with Add-ons disabled) after reboot?  I suspect something else is interfering here.
    Sep 13, 2012 10:05 AM   in reply to Chris Campbell
    Disabling Ad-Ons didn't help, so I tried disabling all Plug-ins in Firefox manually except Shockwave Flash and reinstalled Flash.  I then verified that Flash was working with Youtube and rebooted the computer.  After reboot, Flash did not work with Youtube.  Shockwave Flash was still listed as enabled in Firefox Plug-ins.
    Thanks for your continued help.
  • Chris Campbell
    May 4, 2010
    Sep 14, 2012 6:26 PM   in reply to darkin99
    Could you try disabling protected mode to see if that makes a difference, see the bottom of this FAQ
    How do I troubleshoot Flash Player's protected mode for Firefox?
    Other than that, if Flash Player is loading in Firefox (which it appears it is, at least in about:plugins) then I'd recommend posting on the Mozilla forums to see if anyone else has encountered this issue.
    Sep 14, 2012 6:31 PM   in reply to Chris Campbell
    Chris:
    There are a lot of comments on the Firefox site re: this problem but I haven’t had the time to work it there yet.  Thanks for trying.
