When i try to install photoshop, this happens. Any help would be very aprecialted! Im on a mac 10.6.8.
Exit Code: 6
Please see specific errors and warnings below for troubleshooting. For example, ERROR: DF024, DW063 ... WARNING: DW016 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 16 error(s), 4 warning(s)
WARNING: DW016: NOTE: Cannot set action to the payload {0256558F-A0FF-4FCF-99C2-96D2EE3201D9} Suite Shared Configuration CS6 3.0.0.0 as it is already upgraded by the payload {C346BBCF-A687-4500-BB19-EE9C2D6FF284} Suite Shared Configuration CS6 3.0.0.0
----------- Payload: {0C4E7429-E920-4125-980E-029A87AE0A4D} AdobeColorCommonSetCMYK CS6 4.0.0.0 -----------
ERROR: DF024: Unable to preserve original file at "/Library/ColorSync/Profiles/Profiles" (Seq 21)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 21)
----------- Payload: {C7B1C1B3-368D-4C32-A818-83F1554EB398} AdobeColorCommonSetRGB CS6 4.0.0.0 -----------
ERROR: DF024: Unable to preserve original file at "/Library/ColorSync/Profiles/Profiles" (Seq 11)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 11)
----------- Payload: {48623899-C152-457D-9B30-1F957332AC2F} AdobeColorPhotoshop CS6 4.0.0.0 -----------
ERROR: DF024: Unable to preserve original file at "/Library/ColorSync/Profiles/Profiles" (Seq 3)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 3)
----------- Payload: {78E38D75-4D92-4F6E-B631-17A436BED680} AdobeColorVideoProfilesCS CS6 4.0.0.0 -----------
ERROR: DF024: Unable to preserve original file at "/Library/ColorSync/Profiles/Profiles" (Seq 5)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 5)
----------- Payload: {9124DF4E-617D-486B-A970-8FA632244F24} Adobe Photoshop CS6 Core 13.0.0.0 -----------
ERROR: DF024: Unable to preserve original file at "/Library/ColorSync/Profiles/Profiles" (Seq 2259)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 2259)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - AdobeColorCommonSetCMYK CS6: Install failed
ERROR: DW050: - Adobe Photoshop CS6 English Language Pack_AdobePhotoshop13-en_US: Install failed
ERROR: DW050: - AdobeColorPhotoshop CS6: Install failed
ERROR: DW050: - AdobeColorVideoProfilesCS CS6: Install failed
ERROR: DW050: - Adobe Photoshop CS6 Core: Failed due to Language Pack installation failure
ERROR: DW050: - AdobeColorCommonSetRGB CS6: Install failed
It seems few color profiles have got corrupted.
Please Run following command on terminal on the machine (this will remove the corrupt profiles and should allow you to run the installer successfully) -
sudo mv /Library/ColorSync/Profiles/Profiles /Library/ColorSync/Profiles/Profiles_bkup
Restart your system then try installing PS again, issue should get resolved.
Ashutosh
You do not write anything. You do it the easy way, which also is the way which avoids typos. Copy from the forum and paste into Terminal.
The command is one line which has been split by the forum software. Drag your mouse over the lines to highlight the entire command as shown below, copy, then paste into Terminal.
I am not saying that the command is correct or incorrect, I'm only telling you how to copy and paste it.
How can you have a computer and you not know who the administrator is? Is it a matter of not understanding the terminology? Is this not your computer?
Does your system prompt you for credentials when installing something? If so, what do you enter if not the administrator's credentials?
-Noel
