Missing filters
Sep 6, 2012 6:31 PM
I am using 64 WIndows version of CS5.5. Even my basic filters (blur/gaussian) are missing from the dropdown menu. Please help.
Regards
SYheet
    Sep 6, 2012 7:45 PM   in reply to sujeet.the.mixer
    Check to see what image is.  Some tools/filters only work on 8 bit RGB files.  Look in Image/mode
    Sep 7, 2012 2:53 AM   in reply to sujeet.the.mixer
    There are some filters that doesn't work on 64 Bits,try this :
    - Go to Image -> mode and verifiy that the image is opened in 8bits/channel mode (like advised by CurtY).
    - If it doesn't work,try to launch 32bits version (both are installed on your machine) and test it
  • PECourtejoie
    Jan 11, 2006
    Sep 7, 2012 3:04 AM   in reply to sujeet.the.mixer
    Hello!
    Could you state if they are not visible, or just greyed out.
    Do post the contents of help>System info...
    Did you move the Photoshop install out of its default location?
    Sep 7, 2012 3:09 AM   in reply to sujeet.the.mixer
    And now for the less likely possibility: They could have been hidden with Edit > Menus.
    If so there should be a item saying something like »Show All Menu Items« in the menu.
    Jan 31, 2013 9:29 PM   in reply to sujeet.the.mixer
    Could you be more specific as to what 3D filter your talking about?
    Feb 7, 2013 6:48 PM   in reply to sujeet.the.mixer
    Normally that 3D Engine filter shouldn't cause those kind of problems.
    If you want to get photoshop working properly some more information is needed.
    (put the 3d engine plugin back in before doing any of the below)
    Did you try resetting the photoshop cs5 preferences?
    http://forums.adobe.com/thread/375776?tstart=0
    Have you updated your graphics card drivers from the gpu makers site (not through windows update)?
    Could you post your photoshop cs5 system info as PECoutrtejoie requested?
    (from withing photoshop cs5: Help>System Info)
