mgrhine
Indesign CS2 PDF "unable to view this file"
Apr 28, 2011 3:58 PM
I recently migrated from XP to Windows 7. I'm running Indesign CS2 (all updates applied) and Adobe Reader 9 (only). While in Indesign when I export a PDF, I select 'View PDF after Exporting' then hit the EXPORT button. The PDF is created OK but I get this error message : Unable to view this file because Acrobat was not found. Check your Acrobat Installation. Adobe Reader works fine otherwise. Any ideas?
Marje
    Apr 28, 2011 4:18 PM   in reply to mgrhine
    Do PDFs open up OK in Reader by default when you click on them?  It's probably simply because CS2 isn't supported in Windows Vista or 7 because of it's age, if you ran it on XP you wouldn't have a problem. There is a compatibility mode in 7 that you could try, but seeing this is a problem with it not interacting with other programs correctly I don't have high hopes for you.
    Have a look at this post here for some CS2 upgrade tips.  As Bob points out if you do have the money and need to upgrade now is the perfect time to do it.
    Sep 7, 2012 12:51 AM   in reply to Stix Hart
    I have the same issue with ID CS4 trying to open a pdf after export.
    It comes with the following error: unable to view this file because acrobat was not found. check your acrobat installation
    The PDF file can be opend fine using Reader.
    Tried to repair Reader but with no luck.
    Sep 7, 2012 4:15 AM   in reply to Mahj@Ferring
    What's the OS? Do you have Acrobat Pro installed, or just Reader? What application is set to open PDFs?
    Sep 7, 2012 4:36 AM   in reply to Peter Spier
    It is running on Windows 7 and it does have Acrobat Pro 8.2.6 with Reader X also. It is set to Reader should be default.
    Sep 7, 2012 4:46 AM   in reply to Mahj@Ferring
    I don't know for sure, but I suspect having both Pro 8 and Reader X installed is the problem.
