I recently migrated from XP to Windows 7. I'm running Indesign CS2 (all updates applied) and Adobe Reader 9 (only). While in Indesign when I export a PDF, I select 'View PDF after Exporting' then hit the EXPORT button. The PDF is created OK but I get this error message : Unable to view this file because Acrobat was not found. Check your Acrobat Installation. Adobe Reader works fine otherwise. Any ideas?
Marje
Do PDFs open up OK in Reader by default when you click on them? It's probably simply because CS2 isn't supported in Windows Vista or 7 because of it's age, if you ran it on XP you wouldn't have a problem. There is a compatibility mode in 7 that you could try, but seeing this is a problem with it not interacting with other programs correctly I don't have high hopes for you.
Have a look at this post here for some CS2 upgrade tips. As Bob points out if you do have the money and need to upgrade now is the perfect time to do it.
