kevin_stagg
Can't find my arrowheads that I had configured for the Line tool
Sep 6, 2012 2:33 PM
Tags: #photoshop #line #arrow #cs5+ #arrowheads
Yes, I know where the options to select the arrowheads are (ex: start/end, concavity...etc). But when I create my line, none of the arrowheads are displayed. Not sure what the problem is? Is there an option I may have inadvertently selected which may have turned these off? I am using in Windows Photoshop 5.5. I've used them on this desktop before, again - not sure what's going on here.
Also, is there an option to add arrowheads automagically to the Pen tool in photoshop?
Many thanks -
@kstagg
    Sep 6, 2012 2:48 PM   in reply to kevin_stagg
    Some tool only work in 8 bit RGB mode.  So check Image/mode to see what you have.
    Sep 7, 2012 1:00 AM   in reply to kevin_stagg
    Try resetting the line tool by right clicking on the line icon and choosing reset tool:
    And check that the color in the tool options bar is not the same as the document color.
    If that doesn't help could you post a screenshot?
    Your talking about photoshop cs5 and not the old photoshop 5.5?
    In case it is photoshop 5.5 reset the line tool under (window>options) Line Options
    Also check that the foreground color in the toolbox is not the same color as the document.
    Message was edited by: R_Kelly
  • Noel Carboni
    Dec 23, 2006
    Sep 7, 2012 7:03 AM   in reply to kevin_stagg
    It's reasonable that the numbers should be large, but if you didn't change them it's worrisome that the values were changed.
    -Noel
