Mrbo0m
Flash rookie needs help with error messages when making simple calculator in AS3.
Sep 7, 2012 6:13 AM
Tags: #error #as3 #action_script_3 #string #variable #cs6 #calculator #rookie #error_messages #help_needed
I am trying to make a simple calculator I have been following this guide:
http://www.youtube.com/watch?v=5k3h37YKZJI
this is my code.
var Hnum:String;
var PCnum:String;
var calc:Number = 25;
var Total:String;
num1.restrict = "0-9";
num2.restrict = "0-9";
Est_btn.addEventListener(MouseEvent.CLICK, calculate);
function calculate(event:MouseEvent):void{
    Hnum = num1.txt;
    PCnum = num2.txt;
    Total = parseInt(Hnum) * calc;
    Total.toString();
    Total_txt.text = String(Total);
I am getting these 3 errors:
Scene 1, Layer 'Actions', Frame 1, Line 141067: Implicit coercion of a value of type flash.text:TextField to an unrelated type String.
Scene 1, Layer 'Actions', Frame 1, Line 151067: Implicit coercion of a value of type flash.text:TextField to an unrelated type String.
Scene 1, Layer 'Actions', Frame 1, Line 161067: Implicit coercion of a value of type Number to an unrelated type String.
I have two input text boxs named num1 and num2 and then one dynamic text box named Total_txt.
This should be so simple I really don't know what im doing wrong?
Any help would be really appreciated.
MrB
    Sep 7, 2012 7:13 AM   in reply to Mrbo0m
    If you look at the tutorial I think you will see that you are using "txt"  where "text" is required.  "text" is a property of a textfield, identifying the text that the textfield holds.  I don't know if you are doing something where the num1 object contains another object named txt, but I think my first sentence catches the problem.
    Sep 7, 2012 8:58 AM   in reply to Mrbo0m
    You're welcome
