BrickGun
The titler window does not open in CS5.5, help?
Sep 6, 2012 8:35 PM
Tags: #cs5 #crash #windows #creative #title #titler
I have had Cs5.5, student version for about 8 months now, I have never had a problem with the titler before and now it won't open. I have treid all the diffrent way's to open, and I get nothing. It will open the fist box where you type in the name of the title and decide the frame rate and all that and then nothing. It will also put a new icon in the list of scenes but when I click it it doesnt do anything. I have rerad that deleting the Premier Pro Prefs file can help with title bugs but I do not know how to locate that file. Can someone help please? I am running windows 7.
    Sep 6, 2012 8:39 PM   in reply to BrickGun
    Have you added any fonts, since it last worked?
    For problems with Titler, and fonts, see this article: http://forums.adobe.com/thread/479026?tstart=0
    Good luck,
    Hunt
    Sep 6, 2012 8:55 PM   in reply to BrickGun
    When something works one day, but not the next, then something has changed. The fonts issue is an easy one, but with no new ones, then it is possible that one, or more, of the installed fonts has become corrupted.
    While fonts are not the only possibility, they ARE a common problem. Titler is very sensitive to fonts, either corrupt ones, or badly written ones, that are not exactly "corrupt."
    Good luck,
    Hunt
    Sep 7, 2012 7:56 AM   in reply to BrickGun
    If the uninstall/reinstall does not work, then try the font removal method, outlined in the article: remove half (leaving the System Fonts), and test. If that fixes things, then reinstall half of those removed, and test. If not, then remove half of the half remaining, and test, etc.
    A font does not have to be corrupt to cause problems. It can just be poorly-written.
    Good luck,
    Hunt
