How do I transfer photos from iPhoto to Adobe Elemnet?
Hi
iPhoto is a software application used to import, organize, edit, print, and share digital photos on a Mac OS.
Elements Organizer 10 supports importing photos from iPhoto '09 (versions 8.0 – 8.1.2) and iPhoto’11 (versions 9.0 – 9.1.3). You cannot import photos from versions previous to iPhoto '09.
Import photos from iPhoto ‘09
Elements Organizer 10 supports importing photos, along with their associated captions, tags, and ratings, from iPhoto. You also have the option to import information such as events and albums to maintain the organization of your library
Import photos from iPhoto ‘11
Select File > Get Photos And Videos > From iPhoto. Click Import.
I also a got an article for a quik reference.
http://helpx.adobe.com/photoshop-elements/kb/photoshop-elements-iphoto -mac-os.html
Bingo
Hope It Helps
If you want to keep using iphoto (I'll assume you do unless you post back and say otherwise), you have two choices:
1. Set up PSE as your external editor and send the photos from iphoto to PSE for editing. In this case iPhoto will remember one version + original. (The article linked in _techkid123_'s post explains how to do this.
2. Export the photos from iPhoto, use file>open in the editor, save the photos with a new name, and then reimport the edited photos as new images. The advantage of this method is that you can save as many different versions as you like.
