Flash is complaining about XML? Im using AS3 why are there XML errors? Unknown syntax errors.
Sep 7, 2012 9:04 AM
Tags: #error #xml #action_script_3 #cs6 #syntax #syntax_error #rookie
Sorry to keep spamming these forums with my stupid errors, but I am trying really hard to learn Flash/AS3 and when I have got to grips with it, I will return the love.
I am a flash rookie trying to make a simple calculation device and I am getting a whole world of errors I have never seen before.
My Code (I apologise but it may be my bad syntax):
import flash.ui.Mouse;
var Hnum:String;
var PCnum:String;
var calc:Number = 25;
var Total:Number;
num1.restrict = "0-9";
num2.restrict = "0-9";
Est_btn.addEventListener(MouseEvent.CLICK, calculate);
function PartCount(event:MouseEvent):void{
    PCnum = num2.text;
    if (PCnum > 0 && < 10){
        parseInt(PCnum) * 10;
    or if (PCnum > 11 && < 20){
        parseInt(PCnum) * 5;
    or if (PCnum > 21){
        parseInt(PCnum) * 1;
function calculate(event:MouseEvent):void{
    Hnum = num1.text;
    PCnum = num2.text;
    Total = parseInt(Hnum) * calc + parseInt(PCnum);
    Total.toString();
    Total_txt.text = String(Total);
I had everything working when I was only calculating Hnum by 25. But when I try to intergrate  the if or statement everything goes wrong and I get these 5 errors.
Scene 1, Layer 'Actions', Frame 1, Line 151104: invalid xml name
Scene 1, Layer 'Actions', Frame 11084: Syntax error: expecting xmltagendend before end of program.
Scene 1, Layer 'Actions', Frame 11084: Syntax error: expecting rightparen before end of program.
Scene 1, Layer 'Actions', Frame 11084: Syntax error: expecting identifier before end of program.
Scene 1, Layer 'Actions', Frame 11084: Syntax error: expecting rightbrace before end of program.
I dont understand what these errors are pointing out? Why XML? is it my variable names?
Here is the code I had before the second function that worked fine:
var Hnum:String;
var PCnum:String;
var Total:Number;
     Hnum = num1.text;
     PCnum = num2.text;
     Total = parseInt(Hnum) * calc;
     Total.toString();
Any help would be greatly appreciated! I will get the hang of this!
MrB
  • kglad
    Jul 21, 2002
    Sep 7, 2012 9:27 AM   in reply to Mrbo0m
    those errors appear to be unrelated to that code.
    make sure you're not using a document class and save your fla in a new directory.
    if those don't resolve the problem, use movie explorer to search for all actionscript in your fla.  there may be more code than you are showing.
    Sep 7, 2012 9:33 AM   in reply to Mrbo0m
    Maybe is a parse problem
    check:
      PCnum = num2.text;
        if (PCnum > 0 && < 10){  // <   you're comparing text against numbers and <10 es comparing agaist nothing this can be a bitwise
    instead use
      PCnum = int(num2.text);
        if (PCnum > 0 && PCnum< 10){
  • kglad
    Jul 21, 2002
    Sep 7, 2012 12:05 PM   in reply to esdebon
    you're correct esdebon:
    is causing all those errors.
  • kglad
    Jul 21, 2002
    Sep 14, 2012 4:07 AM   in reply to Mrbo0m
    your code has several problems (the most problematic is that Pmath is never assigned a number).  see your duplicate thread for the list of problems.
    Sep 14, 2012 8:40 AM   in reply to Mrbo0m
    var Hnum:String;
    var PCnum:String;
    var PCcalc:Number;
    var Pmath:Number=1; // <--- Initial value????
    var Total:Number;
        if (parseInt(PCnum) > 0 && parseInt(PCnum)< 10){
            PCcalc = 1;
        if (parseInt(PCnum) > 11 && parseInt(PCnum)< 20){
            PCcalc = 2;
        if (parseInt(PCnum) > 21 && parseInt(PCnum)<200){
            PCcalc = 3;
    function PartCalc(event:MouseEvent):void{
        if (PCcalc == 1){
            Pmath *= 10;
        if (PCcalc == 2){
           Pmath *= 5;
        if (PCcalc == 3){
            Pmath *= 1;
        Hnum = num1.text;
        PCnum = num2.text;
        Total = parseInt(Hnum) * calc + Pmath;
        Total.toString();
  • kglad
    Jul 21, 2002
    Sep 17, 2012 7:52 AM   in reply to Mrbo0m
    again, your code has several problems (the most problematic is that Pmath is never assigned a number).  see your duplicate thread for the list of problems.
    here are the points made in your duplicate thread:
    1. you have 3 lines of code that are the same (your addEventListener code).
    2. you never call PartCalc and you never call PartCount
    3. even if you call PartCalc, it does nothing. in particular, it fails to define Pmath.
    4. Pmath is always NaN. you need to assign it a value.
  • kglad
    Jul 21, 2002
    Oct 1, 2012 9:31 PM   in reply to Mrbo0m
    you're welcome.
