Back Versioning - (if thats a word)
Sep 7, 2012 12:21 PM
I have ps cs5. I need to send a file to someone with ps cs3.
what needs to be done?
    Sep 7, 2012 12:56 PM   in reply to Preditor Corbett
    Do you mean Photoshop when you say PS or do you mean Premiere Pro?
    Sep 7, 2012 1:20 PM   in reply to Preditor Corbett
    [Moved to Photoshop Forum]
    Sep 7, 2012 1:57 PM   in reply to Jeff Bellune
    Are you wanting to continue working on or at least view a PS-CS5 PSD in PS-CS3 and wondering if everything you’ve done will be understood by the older version?  I think it depends on what you’ve done, if the operations in the PSD are actually understood by the older version or not.  Much of the additions of CS4 and CS5 were usage improvements, not how things are represented in the PSD document, itself, so you might be ok just opening the PS-CS5 PSD back in PS-CS3.  Some 3D and animation or video things might be the most different.  How complicated of a document is it?
  • Noel Carboni
    Dec 23, 2006
    Sep 7, 2012 4:22 PM   in reply to Preditor Corbett
    There's really no easy way to know whether you've done things in the new version that won't be understood by the old one, but as has been mentioned there aren't that many things.  I can't think of too many offhand, though one that comes to mind is nesting things in groups more deeply.
    Let them know it was saved by a newer version and to get back to you for a simpler version if they can't open it.
    I still have all the old versions installed here for the times when I want to double check compatibility.
    -Noel
    Sep 7, 2012 5:23 PM   in reply to Preditor Corbett
    I would include the font, as is, so that it can be installed into the system of the other user. Note: be sure to check on the restrictions of use of the font. That can differ, foundry to foundry, and we do want to keep things perfectly legal.
    As others have stated, a generic PSD file should open just fine in either version of the program. Checking Compatibility is always a good idea. *
    Good luck,
    Hunt
    * Though they came from the same Production Studio, and/or Production Premium (I have both, and cannot recall which program came from which, as they are very similar.), I had some issues with PSD's from Photoshop, that would NOT Place in the same version of InDesign, until I checked the Compatibility option. Not supposed to work that way, but in my case it did. One checkbox, and all was copacetic.
