finnegan0
Opening files in CS6 Photoshop & images are blank
Sep 7, 2012 11:11 AM
I just installed CS6 and tried opening CS5 psd files but they appear blank even though I can see the images in the layer thumb nails.  Is there something that could be hiding the layers?
I meet thewindows system requirements but my memory usage is almost at 4GB just having photoshop open.  What is causing this?
    Sep 7, 2012 1:29 PM   in reply to finnegan0
    Moving this discussion to the Photoshop General Discussion forum.
    Sep 7, 2012 1:48 PM   in reply to finnegan0
    OK, and assuming that you are on Windows from the last comment, what is the make/model of your video card? Next, what is the date and number of your installed video driver? Is that the latest from the nVidia, or ATI Web site?
    Last, when looking at the Layers Palette, what do you see for the Layers? Is Visibility (the eyeball to the left) turned ON for all?
    Maybe post a screen-cap of one of those Images Open, with the Layers Palette visible?
    Good luck,
    Hunt
  • Noel Carboni
    Dec 23, 2006
    Sep 7, 2012 4:50 PM   in reply to finnegan0
    Bill is on the right track.  Outdated or buggy display driver is my bet.
    If disabling the use of the Graphics Processor in the Edit - Preferences - Performance dialog (then restarting Photoshop) works around the problem, you need an updated display driver.
    -Noel
    Sep 9, 2012 11:58 AM   in reply to finnegan0
    Glad that you have a workaround.
    If ATI/AMD says that you have the latest (I am not 100% sure how accurate their driver utility is, so you might want to verify that you DO have their latest), that should be fine. However, if you let Windows tell you, it will most likely be at least 6 mos. out of date. Same for most 3rd party driver utilities. I feel that they are NOT to be trusted, and I always verify the driver number & date on my system. I do not bother to have nVidia survey my system. I just go to drivers and check number and date.
    Good luck,
    Hunt
    PS - Noel knows the ATI/AMD cards and drivers, far better than I do (nVidia guy here), so he would be a great resource for discussing the drivers and their settings.
  • Noel Carboni
    Dec 23, 2006
    Sep 9, 2012 12:25 PM   in reply to finnegan0
    Go into Photoshop's Help - System Info... menu and copy the top section, and past it in a post here (you might want to redact the Serial Number info).  That will tell us just what you're running.
    Catalyst 12.8 is the latest package release from AMD/ATI, but the System Info readout won't correllate directly to that (that would just be too easy).  However, we can determine the specifics from what's there.  Here's what my Catalyst 12.8 (latest release) is reporting for individual versions:
    -Noel
    Sep 9, 2012 12:36 PM   in reply to Noel Carboni
    Dear Noel,
    I have had exactly the same problem when I updated my photoshop to CS6. Disabling the processor enabled me to see the imported pictures that previously had only been visible as thumbnails in the layers.
    I have copied my system info and pasted it below.
    Your help in this matter is very much appreciated.
    David
    Adobe Photoshop Version: 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00) x32
    Operating System: Windows Vista 32-bit
    Version: 6.0 Service Pack 2
    System architecture: Intel CPU Family:6, Model:7, Stepping:10 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1
    Physical processor count: 2
    Processor speed: 2094 MHz
    Built-in memory: 3038 MB
    Free memory: 998 MB
    Memory available to Photoshop: 1670 MB
    Memory used by Photoshop: 60 %
    Image tile size: 128K
    Image cache levels: 4
    OpenGL Drawing: Disabled.
    OpenGL Drawing Mode: Advanced
    OpenGL Allow Normal Mode: True.
    OpenGL Allow Advanced Mode: True.
    OpenGL Allow Old GPUs: Not Detected.
    Video Card Vendor: ATI Technologies Inc.
    Video Card Renderer: ATI Mobility Radeon HD 4530
    Display: 1
    Display Bounds:=  top: 0, left: 0, bottom: 768, right: 1366
    Video Card Number: 2
    Video Card: LogMeIn Mirror Driver
    OpenCL Unavailable
    Driver Version: 2.50.596
    Driver Date: 20080811114034.000000-000
    Video Card Driver:
    Video Mode:
    Video Card Caption: LogMeIn Mirror Driver
    Video Card Memory: 512 MB
    Video Rect Texture Size: 8192
    Video Card Number: 1
    Video Card: ATI Mobility Radeon HD 4530
    OpenCL Unavailable
    Driver Version: 7.01.01.849
    Driver Date: 20081231140052.000000-000
    Video Card Driver: atidxx32.dll,atidxx64,atiumdag.dll,atiumdva.cap,atiumd64,atiumd6a,ati tmm64
    Video Mode: 1366 x 768 x 4294967296 colors
    Video Card Caption: ATI Mobility Radeon HD 4530
    Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6\
    Temporary file path: C:\Users\David\AppData\Local\Temp\
    Photoshop scratch has async I/O enabled
    Scratch volume(s):
      C:\, 454.6G, 235.0G free
    Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6\Required\
    Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6\Plug-ins\
    Additional Plug-ins folder: not set
    Installed components:
       A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
       ACE.dll   ACE 2012/06/05-15:16:32   66.507768   66.507768
       adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
       AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
       AdobeOwl.dll   Adobe Owl 2012/06/26-12:17:19   4.0.95   66.510504
       AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
       AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1654
       AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
       AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
       AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
       adobe_caps.dll   Adobe CAPS   6,0,29,0
       AGM.dll   AGM 2012/06/05-15:16:32   66.507768   66.507768
       ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
       aif_core.dll   AIF   3.0   62.490293
       aif_ocl.dll   AIF   3.0   62.490293
       aif_ogl.dll   AIF   3.0   62.490293
       amtlib.dll   AMTLib   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
       ARE.dll   ARE 2012/06/05-15:16:32   66.507768   66.507768
       AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
       AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
       Bib.dll   BIB 2012/06/05-15:16:32   66.507768   66.507768
       BIBUtils.dll   BIBUtils 2012/06/05-15:16:32   66.507768   66.507768
       boost_date_time.dll   DVA Product   6.0.0
       boost_signals.dll   DVA Product   6.0.0
       boost_system.dll   DVA Product   6.0.0
       boost_threads.dll   DVA Product   6.0.0
       cg.dll   NVIDIA Cg Runtime   3.0.00007
       cgGL.dll   NVIDIA Cg Runtime   3.0.00007
       CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
       CoolType.dll   CoolType 2012/06/05-15:16:32   66.507768   66.507768
       data_flow.dll   AIF   3.0   62.490293
       dvaaudiodevice.dll   DVA Product   6.0.0
       dvacore.dll   DVA Product   6.0.0
       dvamarshal.dll   DVA Product   6.0.0
       dvamediatypes.dll   DVA Product   6.0.0
       dvaplayer.dll   DVA Product   6.0.0
       dvatransport.dll   DVA Product   6.0.0
       dvaunittesting.dll   DVA Product   6.0.0
       dynamiclink.dll   DVA Product   6.0.0
       ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
       FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
       filter_graph.dll   AIF   3.0   62.490293
       hydra_filters.dll   AIF   3.0   62.490293
       icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
       icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
       image_compiler.dll   AIF   3.0   62.490293
       image_flow.dll   AIF   3.0   62.490293
       image_runtime.dll   AIF   3.0   62.490293
       JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
       libeay32.dll   The OpenSSL Toolkit   0.9.8g
       libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
       libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
       LogSession.dll   LogSession   2.1.2.1640
       mediacoreif.dll   DVA Product   6.0.0
       MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
       msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
       msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
       msvcp71.dll   Microsoft® Visual Studio .NET   7.10.3077.0
       msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
       msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
       msvcr71.dll   Microsoft® Visual Studio .NET   7.10.3052.4
       msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
       msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       pdfsettings.dll   Adobe PDFSettings   1.04
       Photoshop.dll   Adobe Photoshop CS6   CS6
       Plugin.dll   Adobe Photoshop CS6   CS6
       PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (32 bit)   3.0.0.383
       PSArt.dll   Adobe Photoshop CS6   CS6
       PSViews.dll   Adobe Photoshop CS6   CS6
       SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
       ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
       shfolder.dll   Microsoft(R) Windows (R) 2000 Operating System   5.50.4027.300
       ssleay32.dll   The OpenSSL Toolkit   0.9.8g
       tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
       tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
       TfFontMgr.dll   FontMgr   9.3.0.113
       TfKernel.dll   Kernel   9.3.0.113
       TFKGEOM.dll   Kernel Geom   9.3.0.113
       TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
       updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
       WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
       wu3d.dll   U3D Writer   9.3.0.113
    Required plug-ins:
       Accented Edges 13.0
       Adaptive Wide Angle 13.0
       ADM 3.11x01
       Angled Strokes 13.0
       Average 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Bas Relief 13.0
       BMP 13.0
       Camera Raw 7.1
       Chalk & Charcoal 13.0
       Charcoal 13.0
       Chrome 13.0
       Cineon 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Clouds 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Collada 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Color Halftone 13.0
       Colored Pencil 13.0
       CompuServe GIF 13.0
       Conté Crayon 13.0
       Craquelure 13.0
       Crop and Straighten Photos 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Crop and Straighten Photos Filter 13.0
       Crosshatch 13.0
       Crystallize 13.0
       Cutout 13.0
       Dark Strokes 13.0
       De-Interlace 13.0
       Difference Clouds 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Diffuse Glow 13.0
       Displace 13.0
       Dry Brush 13.0
       Eazel Acquire 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Embed Watermark 4.0
       Extrude 13.0
       FastCore Routines 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Fibers 13.0
       Film Grain 13.0
       Filter Gallery 13.0
       Fresco 13.0
       Glass 13.0
       Glowing Edges 13.0
       Grain 13.0
       Graphic Pen 13.0
       Halftone Pattern 13.0
       HDRMergeUI 13.0
       IFF Format 13.0
       Ink Outlines 13.0
       JPEG 2000 13.0
       Lens Blur 13.0
       Lens Correction 13.0
       Lens Flare 13.0
       Liquify 13.0
       Matlab Operation 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Measurement Core 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Mezzotint 13.0
       MMXCore Routines 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Mosaic Tiles 13.0
       Multiprocessor Support 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Neon Glow 13.0
       Note Paper 13.0
       NTSC Colors 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Ocean Ripple 13.0
       Oil Paint 13.0
       OpenEXR 13.0
       Paint Daubs 13.0
       Palette Knife 13.0
       Patchwork 13.0
       Paths to Illustrator 13.0
       PCX 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Photocopy 13.0
       Photoshop 3D Engine 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Picture Package Filter 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Pinch 13.0
       Pixar 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Plaster 13.0
       Plastic Wrap 13.0
       PNG 13.0
       Pointillize 13.0
       Polar Coordinates 13.0
       Portable Bit Map 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Poster Edges 13.0
       Radial Blur 13.0
       Radiance 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Read Watermark 4.0
       Reticulation 13.0
       Ripple 13.0
       Rough Pastels 13.0
       Save for Web 13.0
       ScriptingSupport 13.0.1
       Shear 13.0
       Smart Blur 13.0
       Smudge Stick 13.0
       Solarize 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Spatter 13.0
       Spherize 13.0
       Sponge 13.0
       Sprayed Strokes 13.0
       Stained Glass 13.0
       Stamp 13.0
       Sumi-e 13.0
       Targa 13.0
       Texturizer 13.0
       Tiles 13.0
       Torn Edges 13.0
       Twirl 13.0
       Underpainting 13.0
       Vanishing Point 13.0
       Variations 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Water Paper 13.0
       Watercolor 13.0
       Wave 13.0
       WIA Support 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       Wind 13.0
       Wireless Bitmap 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
       ZigZag 13.0
    Optional and third party plug-ins: NONE
    Plug-ins that failed to load: NONE
    Flash:
       Mini Bridge
       Kuler
    Installed TWAIN devices: NONE
    Sep 9, 2012 2:42 PM   in reply to davidculley1@aol.com
    And your video card driver is 4 years out of date.
    Go update the driver from the GPU maker's website, and follow their update instructions.
