I have a page that i wish to display total invoices paid to a particular contractor. This Page is Runnign CF9. I'm using a CFC page to write my queries and a action page to display the output via a search box from a search page. Whenever i input the invoice id, coldfusion throws the error: Variable RECENT_INVOICE is undefined" Am i missing something? my syntax is written below:
<!---CFC PAGE--->
<cfcomponent>
<cffunction name="getinvoice" access="public" returntype="query">
<cfquery name="recent_invoice" datasource="w9">
SELECT invoice.*, project.*, bid.*, CONCAT(w9.w9fname,' ', w9.w9lname,' ', w9.w9businessname) AS Contractor, w9.*
FROM invoice, project, bid, w9
WHERE invid = #form.invid#
AND INVOICE.invcontractor = W9.w9ID
AND INVOICE.invproject = PROJECT.proID
AND INVOICE.invproject = BID.bidproject
AND INVOICE.invcontractor = BID.bidcontractor
</cfquery>
<cfreturn recent_invoice>
</cffunction>
</cfcomponent>
<!---Display page that show the invoked query--->
<cfinvoke
component="invoice.componets.test"
method="getinvoice"
returnvariable="recent_invoice">
<!--- CFC Query --->
</cfinvoke>
<!---OUTPUT Items Below--->
<cfoutput>#recent_invoice.invdate# - #recent_invoice.invjob1# - #recent_invoice.invamt1#</cfoutput>
Looks like you are referencing a form field in your query; form.invid. You are not submitting a form, you are calling a cfc so you probably want to add an argument to your function and pass the value when you call it. Change like so:
<!---CFC PAGE--->
<cfcomponent>
<cfargument name="invid" type="numeric" required="true" />
WHERE invid = <cfqueryparam cfsqltype="cf_sql_integer" value="#arguments.invid#" />
</cfquery>
</cffunction>
</cfcomponent>
<cfinvoke
method="getinvoice"
invid="#yourInvoiceNumber#"
</cfinvoke>
Probably. I meant that as a placeholder for you. Just replace #yourInvoiceNumber# with the invoice number that you want to query for (like 8 or whatever). The other variables I gave you, like arguments.invid, do not need to be changed.
If the invoice number truly is coming from a form field prior to the cfc call then you could change #yourInvoiceNumber# to #form.invid# (or whatever).
Does that make sense?
Yes sir. I may be doing something with the text box not being defined. The following error is being thrown: Element INVID is undefined in FORM. i do know thw in my form page the text box is named invid:
<!---CFC PAGE--->
<cfcomponent>
<cfargument name="invid" type="numeric" required="yes"/>
WHERE invid = <cfqueryparam cfsqltype="cf_sql_integer" value="#arguments.invid#"/>
</cfquery>
</cffunction>
</cfcomponent>
<!---FORM PAGE--->
<form action="2_Try_Test_cfc.cfm" method="get" enctype="application/x-www-form-urlencoded" name="form" id="form">
<input name="invid" id="invid" type="text" /><input name="submit" type="submit" />
</form>
<!---INVOKE PAGE--->
<cfinvoke
method="getinvoice"
invid="#form.invid#"
</cfinvoke>
Sorry I didn't reply sooner. Was off-line all weekend.
Without seeing more of your code I can't pinpoint exactly what the issue is. One possibilty is that you have not included a condition around your cfinvoke tag so that it only attempts to call your cfc AFTER the form has been submitted. Something like this:
<cfif IsDefined("form.invid")>
<cfinvoke
method="getinvoice"
</cfinvoke>
<cfelse>
<!---FORM PAGE--->
</form>
</cfif>
That is if the form page is submitting to itself.
If your form page is submitting to a different page (2_Try_Test_cfc.cfm ?) then your cfc call should be in that page with the reference to your #form.invid# variable.
Remember, you can always use <cfdump var="#form#" /> on pages to see what is available (or not).
