.acsm file format converter??
Oct 21, 2008 12:35 PM
  Latest reply: Frustrated in AZ, Sep 8, 2012 6:36 AM
Replies 1 2 3 Previous Next
    May 20, 2011 8:41 AM   in reply to Baron Dugger
    I'm not Mr. Lester, but let me give it a try.  (Jim no longer works for
    Adobe BTW)
    The '.ascm' isn't the .pdf file - it's a set of keys that tell ADE where the
    file is and other information about it.  Think of it as the address of the
    ebook on the shelves of the library.  This is the method that was agreed
    upon to implement the Digital Millenium Copyright Act of 2000 - and there
    won't be any changes to it.
    We have to adjust our way of thinking in the digital age, because technology
    has imposed its own methods on what we used to do in person.  There's not
    many ways to get around using a computer to do what you used to be able to
    do when you visited your library or bookstore.  So, the change that needs to
    take place is not in the system, but with the users of the system.....
    Sorry!
    May 20, 2011 9:45 AM   in reply to Frustrated in AZ
    Referring back to my comments on 14 April:
    Is my problem with Adobe's code as used by Pocket Book or with my Pocket Book 602 itself?
    John.
    May 20, 2011 12:36 PM   in reply to (Cotannah)
    I can not load any .ascm books either and have not been able to for the last 2 weeks.  Not on my pc or my mac.  I am trying to reseach a different way to do this because it doesnt seem that adobe is interested in fixing whatever bug there is.  And byw I use nook.
    May 20, 2011 1:43 PM   in reply to harper syd
    I feel like I'm being drawn into a different conversation.
    Please read my comments about what an '.ascm book' is in the response I
    posted in this thread.  That will put us on a level playing field.  Another
    disclaimer: I am not a MAC guy - and so I can't comment on what may be wrong
    in that environment.  Some of the stuff below pertains to Windows PC's.
    If you're having 'problems', they could be with ADE, they could be with your
    anti-virus software, with the site you're trying to download from or with
    the ebook file itself.  It depends on what's happening to you - and your
    problem is probably not a 'bug' in the software, because thousands of people
    don't have 'problems'.  I hate to  say it like that, because all of us
    assume that the technology we use individually works the same way as it does
    for others.  Here are a couple of ideas to see what you can do to 'get
    around' or 'solve' the problem you have.
    Start with a question: does this happen every time?  If so, you might think
    it's ADE, but it could be another software program on your computer.  Check
    the FAQ's in ADE Help (such as it is) and see if your anti-virus program has
    been reported to cause issues with downloads.  If ADE hasn't said so, it's
    still quite possible, so try disabling your anti-virus program while you
    attempt to download the ebook.
    If there are any error messages that have popped up, you'll have an
    indication whether there is a problem accessing the ebook - and that's not
    ADE's problem.  ADE relys on information that is in the '.ascm' file to
    initiate the download and if there's an error in the ebook file, it won't
    work.
    Also, if you're having problems with one site in your attempts to download,
    it's possible that THEY changed their software - especially if you were fine
    for a while, but now your can't do anything.  Try going to manybooks.net or
    gutenberg.org and see if you can download something from them.
    OK, if none of this works - or you simply don't want to mess with it, you
    can go to a different set of ebook management software.  Bluefire has been
    mentioned, along with Overdrive, in other posts to this message board.  I
    understand that the MAC world likes both of these, and I know that at least
    a few libraries use Overdrive.
    I hope this helps!
    Aug 28, 2011 12:56 PM   in reply to (Cotannah)
    If you still have your 500 and it cannot read ePub, call Sony. They will do one of three things for you. They will either upgrade your 500 to handle ePub via ADE, give you a refurbished 600, or give you a refurbished 650. The update to ePub for the 500 was free. So I'm guessing if you ask Sony about this, they won't charge you.
    Oct 7, 2011 9:40 PM   in reply to (Cotannah)
    I'm having trouble with an ebook I downloaded from the local library. I've got the ACSM file, Adobe Digital Editions is installed, and yet when I try to open the file it will only show the credit page--everything else is blank. I've been trying to figure it out for 3 days now, and it's getting a bit frustrating. Any help with this matter would be appreciated.
    Thank you in advance.
    Yahnkehy4051
    Oct 8, 2011 6:59 AM   in reply to Yahnkehy4051
    There's more than one part to the answer to your question.  Let me assume
    you are running a Windows computer.
    There is no '.ascm file format converter'.  An .ascm 'file' is really just a
    pointer to where the epublication is located, along with some information on
    the epublication.  If it's a library ebook, then the file contains loan
    data.
    What's supposed to happen when you check out a library ebook is that the
    library creates the .ascm file and then activates ADE on your computer to
    'come and get it'.  ADE then will read the .ascm file, and go get the
    ebook.  During this transfer, you should be prompted to 'OPEN' or "SAVE' the
    ebook.  If you choose 'OPEN', then ADE should get the ebook and display it
    in Reading mode.  If you choose 'SAVE', then ADE will import the ebook into
    the Library and display it in Library mode.
    What you're describing happens on the library end - not the ADE end.
    Something is wrong with the ebook file if all you get is one or two pages.
    I've had that happen, and my local library's technical support folks got it
    straightened out.  Good luck!
    Oct 8, 2011 7:20 AM   in reply to Frustrated in AZ
    Date: Sat, 8 Oct 2011 09:17:29 -0500
    Subject: Re: [Adobe Digital Editions] .acsm file format converter??
    since I run a mac, I didnt think I would have any problem.  But my problem is solved, I was gifted with a kindle and Havent had a bit of problem since libraries started kindle lending.  I think kindle is the better of the 2, Nook comes in way down the line syd harper
    Nov 1, 2011 4:53 AM   in reply to Jim Lester
    Thanks Jim.  I had four books and unable to load them.
    Regards, Patrick
    Nov 1, 2011 8:10 AM   in reply to (Cotannah)
    I stopped fighting.  The library says Adobe is at fault, Adobe says the library is at fault.  I have many books that I can not read on the Nook.  So I bought an inexpensive KIndle and can download from all libraries that carry kindle books.  Amazon is amazing about returning the books.  The only books that I now put on the Nook cookbooks and technical books that I buy directly from B/N.  And when I can afford it, I will buy the newest Kindle.  Tired of being frustrated by adobe.
    Jul 5, 2012 3:09 PM   in reply to (Cotannah)
    Isto tudo é uma boa maneira de desviar o nosso dinheiro.
    Comprar um livro e ter que lê-lo no programa que lhes dá na telha não pode ser.
    Queria lê-lo no meu ipad e não posso.
    Estou estremamente aborrecido com o editor e com vontade ne nunca mais comprar um livro.
    Tambem temos o direito de desviar da mesma forma.
    Jul 6, 2012 8:06 PM   in reply to Ferro2010
    I don't speak your language, so I hope you can read my English.
    .ascm files are just address files that tell ADE where to find the ebook
    you want to download.  They are not ebooks themselves.
    Click HERE<http://ebookreadersoftware.wordpress.com/2010/12/10/acsm-files-what-th ey-are-and-how-to-work-with-them/>
    to
    read an article in English that gives you more details.
    Sep 8, 2012 5:56 AM   in reply to (Cotannah)
    (yes I realize this was an older thread, but it's what came up in Google, and it's still very much relevant).
    I check books out from my local library through their digital site.  Most books can be kindle or EPUB -- I read them on iOS, so either one was an option.  The Overdrive app isn't very good, but the Kindle one is.  I don't need special software to use the Kindle format, the deliver the book over the internet to my devices and either way, unlike with the audiobooks, both EPUB and Kindle books actually expire and become unavailable when the checkout period ends.  Since Adobe is considerably more bother to get onto my iphone (requires the use of at least two, if not three, programs) vs a single click after checkout to get the Kindle version -- I'll stick with Kindle.  Sorry Adobe, you shouldn't assume everyone will just use your software...  probably time to reconsider your whole book platform, because you've seriously failed on this one.
    Sep 8, 2012 6:36 AM   in reply to Kvetchus
    Every time this old thread comes back, it reminds me that some people don't
    do their homework.  Your assumption that Digital Editions works with a
    Kindle is incorrect.  And your comment that Adobe doesn't run on your
    iPhone means you don't understand what the design point for Digital
    Editions is.
    I do not apologize for Adobe, nor do I defend them.  I have my own issues
    with Digital Editions, as my screen name would suggest.  If you'd followed
    other threads on the forum, you might have posted your comments on one
    that's a bit more related to them.
    Amazon chose to use a non-standard approach to ebooks, and in doing so,
    implemented a unique file format for their ebooks.  As you're finding out,
    some libraries will lend in Kindle format now, and some other sites like
    Gutenberg.org have 'some' Kindle ebooks.  It's not widespread now, but -
    who knows?  You are somewhat limited by what Amazon has to offer, or what
    other software systems can do for you.
    Digital Editions is designed to be an independent platform that will allow
    users with a very wide range of other ebook readers, to import
    industry-standard format ebooks from a variety of sources.  And no one at
    Adobe thought that, or intended that, everyone would use it.  Adobe still
    don't think that way - it's a niche product.  The design point for Digital
    Editions was put together in the late 1990's.  It was not designed to
    interface with Android devices - which effectively didn't exist when it was
    designed - and does not run on that platform.  Your assumption that it
    should is incorrect.  If you want ebooks on your iPhone, then you do indeed
    have 'better' vehicles that Digital Editions.  Ditto for tablets.  If we
    stop here, then you've posted comments to this forum for no apparent reason
    other than to diss Adobe and Digital Editions.
1 2 3 Previous Next
Actions
