class="wrapper">
<div class="col-1 col-indent">
<h2><strong>ABOUT</stron g> us</h2>
<span class="text">Lorem ipsum dolor sit ame</span>
Aadipiscing elit, sed diam nonummy nibh euismod tincidunt ut laoreet dolore magna. Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam nonummy nibh euismod tincidunt ut laoreet dolore magna.
<p><a href="#" class="link1">more</a></p>
</div>
<h2><strong>Travel</stro ng> with us</h2>
<span class="text">Ipsum dolor sit amet consectetuer</span>
Aadipiscing elit, sed diam nonummy nibh euismod tincidunt ut laoreet dolore magna. Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam nonummy nibh euismod tincidunt ut laoreet dolore set dolor magna.
</div>
<div class="col-1">
<h2><strong>You seek</strong> – we find </h2>
<span class="text">Lorem ipsum dolor sit amet</span>
</div>
</div>
Try validating your code and fix any reported errors.
CSS validator - http://jigsaw.w3.org/css-validator/
HTML validator - http://validator.w3.org/
If that doesn't solve your problem, you'll need to upload your page and supporting files to a web server space you control and post a link here.
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
Even if CSS is internal, at the start of the same html page, I believe DW's default is to only look externally (so then the default needs to change).
Uh... where on Earth did you get this idea?
Dreamweaver can see CSS from an external file, embedded at the top of the page or inline with the HTML code -- assuming the code/file paths don't have errors in them. That is the default. So there is nothing to change.
If Design View can't render the page at all, something is wrong with the code.
Nancy O.
DW will find CSS when the job is correctly set-up, Layout CSS default settings should also be checked out. I inherited this job and experienced the same display issues as JeanaNYC.
YES file path was broken, NO there wasn't anything wrong with the code itself (which may, or may not, be the same issue for JeanaNYC):
Nancy O. wrote:
Dreamweaver can see CSS from an external file.... assuming the code/file paths don't have errors in them.
