Koopdal
Error code 16
Sep 6, 2012 1:03 PM
Tags: #error_code_16
After installing the programs I get everytime error code 16 when I try to start them.
Changing the permissions from the PDC folder and SLstore folder didn't work.
So who can help?
    Sep 7, 2012 5:35 AM   in reply to Koopdal
    This is a permissions problem,if you're on windows,try to right click on the application and choose run as administrator
    Sep 10, 2012 4:45 AM   in reply to Koopdal
    Ok,first be sure you respected this permissions for those folders :
    PCD:
    Owner = System = read/write
    Group = Admin = read only
    Everyone = read only
    Or from the terminal, drwxr-xr-x root admin
    SLSTORE :
    Group = Admin = read/write
    Everyone = read/write
    Or from the terminal, drwxrwxrwx root admin
    otherwise,try this because sometimes changing from permissions menu doesn't take effect :
    open the terminal (Applications > Utilities > Terminal)
    Tape this :
    sudo chmod 777 /Library/Application Support/Adobe/Adobe PCD/
    sudo chmod 777 /Library/Application Support/Adobe/SLStore
    Nov 2, 2012 4:07 PM   in reply to arij2010
    Check the amt3.log and Delete the folder SLcache from HD/library/application support/adobe.
    Mar 22, 2013 9:34 AM   in reply to arij2010
    HI, I don't know what PCD: or SLSTORE: are, so I went to Terminal and pasted "sudo chmod 777 /Library/Application Support/Adobe/Adobe PCD/  sudo chmod 777 /Library/Application Support/Adobe/SLStore"
    Files etc could not be found and I continue to sit with Error: 16 and I cannot access any Adobe applications.
    HELP. I have work to do. Now.
    How do I successfully rectify this problem?
    I am fully paid up on my CreativeCloud account. iMac, OS 10.8.3
    Regards
    Gerd
    Mar 25, 2013 8:48 AM   in reply to Gerd Kalesse
    PCD and Slstore are on this location :
    MAC HD /Library/Application Support/Adobe/ .
    You can also give all permissions to the Adobe folder : MAC HD /Library/Application Support/Adobe .
    Mar 25, 2013 9:31 AM   in reply to rajesh1989
    HI
    I don't know what the amt3.log is, nor where to find it. Same goes for deleting the SL cache. Any further help please
