How can I change Illustrator language to English?
Sep 7, 2012 3:51 PM
Tags: #languages
I have subscripted to Adobe Cloud and downloaded Photoshop/Illustrator but the default language at that time (in my Adobe Application Manager) was Portuguese so it installed the portuguese version of Photoshop and Illustrator.
Changing the language in Adobe Application Manager preferences and re-downloading Photoshop changed its language but the very same procedure didn't look like to work with Illustrator.
Can I have to setup something else in order to make it work?
    Sep 7, 2012 6:57 PM   in reply to MarcosACLima
    You might have to reset the preferences also at the bottom of the characcter panel there is a selection for the language, if it is set to Portuguese currently change it to english
    Sep 8, 2012 12:12 PM   in reply to Wade_Zimmerman
    @Wade , isn't the language in the character pallete is the spell check language for the document /text ?
    Sep 8, 2012 1:15 PM   in reply to MarcosACLima
    On the Macintosh I have to change the system language to get the corresponding application language.
    I have 2 versions installed using the preferences in the Application Manager; at first English and later Dutch.
    When I set the System language in Language and Text in the System Preferences to Dutch and log in again the language changes.
    See also: Installing Multiple Languages of a Desktop Application
    http://tv.adobe.com/watch/cs6-creative-cloud-feature-tour-for-design/i nstalling-multiple-languages-of-a-desktop-application/
    Ton
    Sep 8, 2012 3:10 PM   in reply to MarcosACLima
    Not that i know of.
    Looks like a feature request:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    regards,
    Ton
    Sep 8, 2012 3:45 PM   in reply to Ton Frederiks
    By default the AAM picks the language of the Operating System , which happened at the intial stage and caused this issue.
    On changing the language of the AAM preferences and re-installation ideally should have worked and indeed for the PS but not for the Illustrator unfortunatly.
    So , what has happened here with the Illustrator is you have 2 laguage pack installed Portugese and English and it is picking the language based on the system locale.
    Log in the account (default user account) in which you want the Illustrator to be in English language , uninstall Illustrator and all Cs6 apps ,
    Run the Cleaner tool :- www.adobe.com/support/contact/cscleanertool.html
    Install the Illustartor with the correct language set in the AAM preferences.
    There will be no need to switch the OS language as there would be just English language pack to launch.
    Sep 8, 2012 4:08 PM   in reply to Manish-Sharma
    That is an interesting way to install a specific language while the OS language is different.
    Unfortunately you cannot switch languages then.
    I prefer the Photoshop way: install the languages you want with AAM and just switch between them in the Photoshop Preferences. It just requires a Photoshop restart to switch.
    I think I will fill in the feature request form myself :-)
    Sep 8, 2012 4:13 PM   in reply to Ton Frederiks
    You can and that what is happening here with the Illustrator/
    When OS language is Portugese then the illustartor language is Portugese becuase Illustrator is installed with the portugese language here first.
    but when we re-installed it in English and then switched the OS language to the English , Illustrator was in English.
    I agree that the PS preferences provide a flexibilty but there are many apps that doesn't have this feature like Ai, Indesign , Dreamweaver etc. so, you are more then welcome to fill in the feature request form asking for this feature.
    Sep 8, 2012 4:19 PM   in reply to Manish-Sharma
    Check this :-
    http://helpx.adobe.com/creative-cloud/kb/creative-cloud-trial-mode.htm l
    So , people with english-only subscription doesn't need the English OS , they can have the OS in different language.
    The product need to be installed with the language you want disregard of the OS language.
