2
Unable to Create Outlines with Type on Path
Guest
Sep 08, 2012 Sep 08, 2012
Hello,
I'm using Illustrator CS4. I am unable to Create Outlines for a font after I had used the type on the Path Tool. I had used the ellipse tool to create a closed circular path, then I selected the Type on a Path tool. I selected my text using the arrow tool and ctrl-shift-o (Create outlines) and then I receive the message: "Can't Create type outlines." Not quite sure why this is happening. Did I miss something? The thing is this - my type is in the position and alignment that I want and I don't necessarily want to work with the Type as a Font but as vector shapes. Is there a way or technique to be able to do this? Or is there an alternative? Any hints or direction would be greatly appreciated. Thank you.
srioch
Type
105.4K
New Here , Mar 14, 2017 Mar 14, 2017
I had the same problem, finally found the answer. In order to create outlines of text on a path, you have to select the path--not the type--with the selection tool. Then go to Object >> Expand...
Voila!
Adobe
I do not know what is causing your problem but you can select the text as before and go to Object> Expand or Object>Flatten the Trnasparency either one should work.
It would be nice to see your selected art and the appearance and layers panels expanded so we can see everything it might give a clue.
Guest
Sep 09, 2012 Sep 09, 2012
Wade,
Thank you for the response. Create Outlines is working for me now. The only thing I could conclude was that my PC needed to start afresh after several hours of working on it. Your suggestions was also very helpful!  If it happens again...I'll post a screenshot of my workspace and we can go from there. Thanks again!
srioch
srioc,
I believe you have encountered a simple (preference) corruption of some kind. I usually recommend the following steps for increasingly serious/difficult cases, starting with non destructive measures (step 4) is non destructive, but step 3) is easier); your soultion comprises step 2).
1) Close down Illy and open again;
2) Restart the computer;
3) Close down Illy and press Ctrl+Alt+Shift/Cmd+Option+Shift during startup;
4) Move the folder with Illy closed;
5) Look through and try out the relevant among the Other options;
Even more seriously, you may:
6) Uninstall, run the Cleaner Tool if you have CS3/CS4/CS5/CS6, and reinstall.
http://www.adobe.com/support/contact/cscleanertool.html
Jan 21, 2020 Jan 21, 2020
Great tip Wade! Thank you. I was having the same issue but the Flatten the Transparency with the dialog box was better than Create Outlines.
Jan 26, 2022 Jan 26, 2022
Thank you!  Expand worked perfectly!
Oct 07, 2015 Oct 07, 2015
Hi Srioch,
This happens to me today using CS6. I restarded Illustrator and even my MBP but still the crytical "Can't outline type" appears on every attempts. The problem was that I use 'select all' and 1 of the selected text-elements is in a grouped object and was locked so instead of outlining the selected one, CS6 choses to 'boycot' the whole action leaving the user troubled 🙂
So make sure you release all of the type-elements first before applying the outline command. Hope this helps.
Jun 12, 2016 Jun 12, 2016
That solved my issue.
In my case (same symptoms), I looked in the layers panel and found a hidden layer (containing no text) at the same level as a text layer.
I deleted that empty layer, selected all elements again, and the Type > Create Outlines operation worked.
Voila!
Jun 29, 2019 Jun 29, 2019
Your answer 'you have to select the path--not the type--with the selection tool. Then go to Object >> Expand...'
was the TRICK....!  Thank YOU. . . !
Jun 30, 2019 Jun 30, 2019
So glad it helped!
Sep 11, 2020 Sep 11, 2020
Thank you so much Kr8ful!! This was driving me crazy and tried resetting the preferences and expand the appearance and that didn't work. I hope Illustrator fixes this in their next update.
May 12, 2023 May 12, 2023
Thanks! This helped a ton for me.
Nov 09, 2023 Nov 09, 2023
Thanks to all the great answers & fixes here. In Ai 2024, I had type on a path that encircled a logo.
After selecting just the path the type was on I was able to "Create Outlines" without the exapand step. Maybe this is something new and could help too.
