Cara*
Does anyone know how to disable the auto scroll function in photoshop and creative suite?
Sep 8, 2012 9:15 AM
Tags: #auto #scrolling_speed
I would like to disable the auto scroll function.  I am tired of getting thrown around in photoshop and indesign. Does anyone know if this can be done and if so, how to do it.
    Sep 8, 2012 7:43 PM   in reply to Cara*
    What do you mean by the auto scroll function in photoshop?
  • Noel Carboni
    Dec 23, 2006
    Sep 8, 2012 7:54 PM   in reply to Cara*
    Are you dragging something past the edge of the visible canvas?
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Sep 8, 2012 8:11 PM   in reply to Cara*
    That's not an auto-scroll function, that sounds like a problem with your system.  I never see that when working in Photoshop, and I certainly wouldn't stand for it.  I've seen it reported from time to time though...
    Do you have a wireless mouse?  Wireless keyboard?
    Are  your drivers up to date?
    Any chance anyone as a prank installed one of those stupid devices ThinkGeek sells that are designed to irritate you by generating spurious inputs to your computer?
    I'm not going to be online tonight much longer, but for others who might want to try to help, please list your system type, operating system and version, and Photoshop version, as well as whether you have all your software up to date.
    -Noel
    Sep 8, 2012 8:20 PM   in reply to Noel Carboni
    Good night Noel. Even you are allowed to sleep.
    To me, this sounds like some sort of input interface issue, either mouse, tablet, or perhaps keyboard.
    Those would be where I would begin my search, for the problem.
    Hunt
    Sep 8, 2012 8:27 PM   in reply to Cara*
    Good luck, and please report your tests.
    Hunt
    Sep 8, 2012 8:38 PM   in reply to Bill Hunt
    I seem to remember Logitech wireless mouse having that.
    Sep 8, 2012 9:15 PM   in reply to Cara*
    Is that an apple magic mouse?
    Sep 8, 2012 11:00 PM   in reply to Cara*
    Well therre you have it. It's magic.
    Sep 8, 2012 11:27 PM   in reply to Cara*
    I don't have a magic mouse myself, but you might fool around with some of the mouse settings:
    Sep 9, 2012 9:25 PM   in reply to Cara*
    This is a terrible problem. It happens, for example, when I have a full-page image open, in full screen mode. Doesn't happen when you have a floating window. BUT I am working with projection mapping, so I must work with an actual-size image, fit to the screen exactly. As a result I simply cannot work near the edge of the image. It's ridiculous that software this mature has such a hole! There must be a workaround! It is definitely Photoshop, not the OS interface, that has this "feature."
    Any suggestions welcome....
    thank you.
    Sep 9, 2012 9:45 PM   in reply to 10x Studio
    Well it must be something on your system whether it be a mouse, software or something else because most people aren't having that specific problem.
    If you describe the problem and your operating system and version of photoshop, maybe we can help.
    Nov 13, 2012 9:39 AM   in reply to 10x Studio
    This is a photoshop problem and indeed is `hell` for projection mappers. It is the single pain with using photoshop to `map` on the extended desktop. Any doubters should set up a full screen on their extended desktop and out of a projector and then put a brush mark in the centre of the screen and then whilst holding shift draw a straight line to the edge of the image. The image will immediately jump out of position, done with a selection tool it slides out of position. It is a superior pain and the only solution is to use the `F` key to bring it back to fullscreen. Usually this drops it back to where it was but on some machines it doesn`t even do that right. A switch to turn it off is desperately required!
  • Noel Carboni
    Dec 23, 2006
    Nov 13, 2012 1:53 PM   in reply to John McGeoch
    You're going to have to be more specific, John.
    I just made a 1600 x 1200 pixel image, zoomed to 100%, and used F to go to full screen on monitor 1 (I have two that each display 1600 x 1200 pixels).  I then painted lines with a brush and it just stayed put.  I did not have to use F to bring it back to full screen or anything of the sort.
    Are you saying the image extends beyond what's visible to you at the zoom level you've chosen?  Is there a reason you can't zoom out?
    Don't get me wrong - I'm not being critical of what you want.  I'm just trying to understand whether you're seeing a problem others are not seeing.
    -Noel
    Nov 13, 2012 2:05 PM   in reply to Noel Carboni
    Sorry Noel - create an extended desktop and open photoshop - create a file the same size as your second monitor and drag it over to the second screen. Press F to make it full screen and Ctl 1 to make it actual pixels. We now have just what we require for projection mapping onto say a building assuming the second monitor is a projector. Now take a brush and stamp it in the middle of your page - which is on the second monitor, photoshop itself is on your Ist monitor. If you press hold Shift down and stamp your brush at the edge of your full page you will see it jump too the side. It will also do this if you try to drag a selection too close to the edge. The page will begin to scroll to accomodate the selection which is perhaps useful in some circumstances but in others like to projection map it is a horror because we need the page to remain exactly where it is at all times or it will no longer be `registered` to the architecture previously done. Beleive me
    this can be deeply frustrating when you are out in the cold trying to get all the facets of a building mapped, but even when in the warm trying to do it with a theatre set.
    Should you have a solution then you would indeed become much revered in these parts  - best wishes  John   --
     a couple of mapped buildings done with this method below
    http://vimeo.com/31496197               ness chrurch
    http://vimeo.com/17762125                 xmas lights
  • Noel Carboni
    Dec 23, 2006
    Nov 13, 2012 2:11 PM   in reply to John McGeoch
    Thanks for the clarification.
    I think I may see the problem here...  Are you on a Mac running Mountain Lion, and so the phrase "create an extended desktop" means something special?
    I'm using a PC.  In my case my desktop is always extended across my two monitors, with the Photoshop main window being on monitor 1 and my panels all on monitor 2.  F just makes the image fill monitor 1.
    Thanks as well for clarifying what you mean by "projection mapping".  I've seen that done before and it can be a very cool art form indeed.
    -Noel
    Nov 13, 2012 4:06 PM   in reply to Noel Carboni
    As John says, at least with the two-monitor setup one uses with the projector going, the full-screen (projector) monitor will move with the selection tool near the edge. There is no way to defeat this behavior. My workaround was to abandon the selection lasso and instead use the pen tool. This works fine, there's just an extra step to make the selection. For whatever reason, the pen tool doesn't cause the problem, while selection lasso does. FYI, I was working on lighting the Crossing Borders exhibition at the Jewish Museum in NYC. Check it out if you're in the area. /Eric
    Nov 13, 2012 4:33 PM   in reply to Noel Carboni
    Hi Noel - I`m on a PC - the problem comes when using the second monitor as a full page which it has to be when mapping a building or a set.  - cheers John
    Nov 13, 2012 4:36 PM   in reply to 10x Studio
    Cheers Eric - hadn`t tried the pen, as i said I usually use the Brush tool and the straight line command from holding shift down. On a big building it can be hard seeing the tools that use just a crosshair, the brush can usually be located much easier!  John  - do you have a link to the exhibition?
  • Noel Carboni
    Dec 23, 2006
    Nov 13, 2012 4:37 PM   in reply to 10x Studio
    I just tried relocating selecting the Essentials workspace and relocating my Photoshop application to monitor 2 on my Windows 7 system, on which the desktop extends to both monitors.  Then I opened a 1600 x 1200 image and used the F key twice to get the image to show full screen at 100% zoom.
    I was finally able to create the overscroll behavior you're describing using the selection tool only.  I wasn't able to get the image to move using the brush tool.  Thank you for being patient with me.
    This is one and the same issue as is provided as a workaround for when people would like to be able to overscroll an image that entirely fits in the current view.
    Yes, I agree, there needs to be a setting that specifically allows or disallows overscroll for any size image.  Maybe there would need to be several different settings (e.g., always, only if image zoomed past edges, never).
    -Noel
    Nov 13, 2012 5:10 PM   in reply to Noel Carboni
    Yep - agree it needs those three choices ..............
