dzinedmedia
Illustrator CS6 update keeps failing
Sep 7, 2012 5:24 AM
Tags: #problem #update
Hi Having problems, installation keeps failing
Exit Code: 7
Please see specific errors and warnings below for troubleshooting. For example,  ERROR: DF024, DW063 ... WARNING: DS012, DW016 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 4 error(s), 8 warning(s)
WARNING: DW016: NOTE: Cannot set action to the payload {0256558F-A0FF-4FCF-99C2-96D2EE3201D9} Suite Shared Configuration CS6 3.0.0.0 as it is already upgraded by the payload {C346BBCF-A687-4500-BB19-EE9C2D6FF284} Suite Shared Configuration CS6 3.0.0.0
----------- Payload: {0C4E7429-E920-4125-980E-029A87AE0A4D} AdobeColorCommonSetCMYK CS6 4.0.0.0 -----------
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 21)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 22)
----------- Payload: {C7B1C1B3-368D-4C32-A818-83F1554EB398} AdobeColorCommonSetRGB CS6 4.0.0.0 -----------
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 11)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 12)
----------- Payload: {AAF0D225-F129-40F2-916E-12E28DBD19ED} Adobe Illustrator CS6 Core 16.0.0.0 -----------
ERROR: DF024: Unable to preserve original file at "/Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/Frameworks/AdobeCrashReporter.framework/Adob eCrashReporter" (Seq 1649)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 1649)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050:  - Adobe Illustrator CS6 Core_AdobeIllustrator16en_GBLanguagePack: Install failed
ERROR: DW050:  - Adobe Illustrator CS6 Core: Failed due to Language Pack installation failure
    Sep 7, 2012 8:55 AM   in reply to dzinedmedia
    Have you run the cleaner tool between reinstall attempts?
    http://www.adobe.com/support/contact/cscleanertool.html
    Try uninstalling again, run the cleaner tool and then reinstall.
    Sep 8, 2012 10:20 AM   in reply to Larry G. Schneider
    Larry,
    That doesn't make sense to me... He's running the update, so why should the cleaner tool be run?
    Cheers!
    S
    Sep 8, 2012 10:21 AM   in reply to dzinedmedia
    dzinedmedia,
    Hi... are you running the AI CS6 Update or Upgrade?
    Cheers,
    S
    Sep 8, 2012 10:34 AM   in reply to shunithD
    @ShunithD
    If you look at the install fail log , then it is written
    The payload is for the Illustrator CS6 Core 16.0.0.0 , hence it is not for the update but the core installation of the Illustrator.
    The reason of the fail is at the time of installation the installor was unable to preserve the original file at "/Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/Frameworks/AdobeCrashReporter.framework/Adob eCrashReporter" ,
    So , on running the Cleaner tool , the "Illustrator.app" got deleted and on re-running the installation , it worked because a fresh illustrator.app was written.
    Sep 8, 2012 8:57 PM   in reply to Manish-Sharma
    @Manish
    So... was the OP running an Update or an Upgrade?
    Sep 9, 2012 7:28 AM   in reply to dzinedmedia
    ok...
