Natasha Jaz
Error while Open and save pdf using Adobe library
Sep 8, 2012 5:43 AM
I m using adobe library to open and save PDF using VC++ MFC .
as given samples are working for me all are using console application to accomplish this task.
But when i tried to use same functions to open and save PDF from DOC/VIEW application it gives me an error.
it is a strange problem that I don't understand. If I compile the following code (Visual C++ 2000 Express Edition) I get an error message: "Unhandled exception at 0x0041183f in test.exe: 0xC0000005: Access violation reading location 0x00000004."
For your reference when I simply  create one function and one menu and called that function from menu.
Please see the code is given below.
The code is given below
void CPDF_MFCDoc::OnPdfOpen()
    // TODO: Add your command handler code here
    OpenPDF();
#define PDF_FNAME1  "C:/Test.pdf"
void OpenPDF()
     PDDoc pdDoc= NULL;
     ASErrorCode errCode = 0;
     DURING
        pdDoc1 = MyPDDocOpen(PDF_FNAME1);
    HANDLER
        errCode = ERRORCODE;
    END_HANDLER
It gives me an error as.
Unhandled exception at 0x004075b1 in PDF_MFC.exe: 0xC0000005: Access violation reading location 0x00000024.
But when same thing I was complied from console ,it works.
Working code is given below.
void MainProc(int argc, char **argv )
     PDDoc pdDoc= NULL,
     DURING
     HANDLER
    END_HANDLER
PDDoc MyPDDocOpen(char *fileName)
    ASFileSys asFileSys = ASGetDefaultFileSys();
    volatile ASPathName asPathName    = NULL;
    volatile PDDoc        pdDoc        = NULL;
    DURING
        /* Create asPathName from file.*/
        #if MAC_PLATFORM
        asPathName = GetMacPath(fileName);
        #else
        asPathName = ASFileSysCreatePathName(asFileSys, ASAtomFromString("Cstring"), fileName, 0);
        #endif
        /* Open pdDoc from asPathName.*/
        pdDoc = PDDocOpen(asPathName, NULL, NULL, true);
        fprintf(stdout, "Successfully opened %s\n", fileName);
    HANDLER
        fprintf(stderr, "Unable to open %s\n", fileName);
        pdDoc = NULL;
    END_HANDLER
    /* Release asPathName.*/
    if (asPathName)
        ASFileSysReleasePath(asFileSys, asPathName);
    return pdDoc;
    Sep 9, 2012 12:29 AM   in reply to Natasha Jaz
    As you are using the Adobe PDFLibrary, you have a support contract with either Adobe or Datalogics.  Contact them directly for support.
    Sep 10, 2012 12:55 AM   in reply to Natasha Jaz
    I think lrosenth has given you the best advice.
