I have a seed catalog that contains a number of varieties within the same heading/category. So, I'm trying to have a number of records (rows from excel/csv) listed in one table versus all separate tables on different pages using data merge. I have set up a table and put the placeholders there but it keeps adding the other records in different tables and pages. What am I doing wrong?
Data Merge cannot add cells to a table. The closest you are likely to come is to use a multiple records per page merge with zero spacing and the frame holding the table exactly the height of the table, but it still probably won't look the way you want it, and you won't be able to have other objects on the page, most likely.
Why not place the Excel file itself, instead of using Data Merge? You can use named ranges in the spreadsheet to isolate sections.
The other option would be to look at real commercial catalog plugins that are designed to do what you need. Data Merge is really much more suited to things like address labels and name badges. It's quite primitive.
When you place the spreadsheet it places as a table. One problem you'll encounter, though, is that ID will not break a cell across columsn or pages, so if there is too much text to fit onthe page in a cell it will bump the whole row, if it can, to the next page or column, leaving a large gap, or it may go into overset.
