funreizer
Script to Open Folder Automatically?
Sep 10, 2012 4:45 AM
Good day,
I've been searching the net for 2 days for something probably simple, but can't find it.
Is there a script that can open all files within a folder automatically?
What I want to do is to have Photoshop open a folder full of files, save each one for web. I can automate save for web part with actions. but can't find a way to import a folder.
Image processor is great, except one thing that annoys the hell out of me which is dialog popup. So I'm looking for script that automatically, without any dialog boxes, opens up all files within a folder.
I found this:
var dir = Folder('Q:/Images');
var selectedFile = dir.openDlg("Select Image" , "Select:*.nef;*.cr2;*.crw;*.dcs;*.raf;*.arw;*.orf;*.dng;*.psd;*.tif;* .jpg;*.png;*.bmp");
if( selectedFile !=null ){open(File(selectedFile));}
but it's a prompt. Is there some script that just loads a folder with files automatically?
thanx
  • JJMack
    Jan 9, 2006
    Sep 10, 2012 6:43 AM   in reply to funreizer
    I'm sure if you look at a script like the Image Processor that ships with Photoshop you will see code to do that. You can just point it at a folder and it will process all the image files it it. There is also a option to process sub foldere so it may show you how to use recursion.
    I quick look I found this in Image Processor
    // Function: FindAllFiles
    // Usage: Find all the files in the given folder recursively
    // Input: srcFolder is a string to a folder
    //                      destArray is an Array of File objects
    // Return: Array of File objects, same as destArray
    function FindAllFiles( srcFolderStr, destArray ) {
              var fileFolderArray = Folder( srcFolderStr ).getFiles();
              for ( var i = 0; i < fileFolderArray.length; i++ ) {
                        var fileFoldObj = fileFolderArray[i];
                        if ( fileFoldObj instanceof File ) {
                                  destArray.push( fileFoldObj );
                        } else { // folder
                                  FindAllFiles( fileFoldObj.toString(), destArray );
              return destArray;
    To do what you want I've used code that looks like this
    // Loop Image File Start
                                  var fileList = inputFolder.getFiles(/\.(nef|cr2|crw|dcs|raf|arw|orf|dng|jpg|tif|psd| eps|png|bmp)$/i);
                                  // Loop through files
                                  for (var i = 0; i < fileList.length; i++) {
    Sep 10, 2012 6:34 AM   in reply to funreizer
    The folder object has a getFiles() method which you can pass a regexp to filter otherwise it will return all files… Lots of samples of this here in this forum…
  • JJMack
    Jan 9, 2006
    Sep 10, 2012 6:57 AM   in reply to funreizer
    Files can be opened, placed, executed, deleted etc in my loop I was placeing files not opening
                                            // Only process the returned file objects
                                            // The filter 'should' have missed out any folder objects
                                            //  get next image file
                                            if (fileList[i] instanceof File) {
                                                      //alert(fileList[i]);
                                                      var layers = activeDocument.layers;
                                                      activeDocument.activeLayer = layers[layers.length-1-imageNumber+1];           // Target Background Layer or last placed image
                                                      placeImage(fileList[i]);                                                      // Place in Image   you would open instead of place
                                                      // Get Smart Object current width and height
  • JJMack
    Jan 9, 2006
    Sep 10, 2012 7:41 AM   in reply to funreizer
    If you know the folder you do not need to put up a select dialog just  process the folder you know.  If you keep on loading image you may start boging down the system. Here some code I used to open files flatten then resize them to tile size copy to clipboard close no save then paste them into place into a new document I'm creating to print images on roll paper.
    var currrow=0; var pasted=0;
                        for (var i=0;i<file.length;i++) {
                                  app.load(file[i]); //load it into documents
                                  var backFile= app.activeDocument; //prepare your image layer as active document
                                  flatten(); //handle layered images
                                  if (backFile.width.value<backFile.height.value&&width>height ) { backFile.rotateCanvas(-90.0);  } // Rotate portraits
                                  if (backFile.height.value<backFile.width.value&&height>width ) { backFile.rotateCanvas(-90.0);  } // Rotate landscapes
                                  if (backFile.width.value/backFile.height.value > width/height) { backFile.resizeImage(null, height, null, ResampleMethod.BICUBIC); } // wider
                                  else {backFile.resizeImage(width, null, null, ResampleMethod.BICUBIC);} // same aspect ratio or taller
                                  backFile.selection.selectAll();
                                  backFile.selection.copy(); //copy resized image into clipboard
                                  backFile.close(SaveOptions.DONOTSAVECHANGES); //close image without saving changes
                                  for (var n=0;n<copies;n++) {
                                            var x =pasted*width;
                                            var y =currrow*height;
                                            var selectedRegion = Array(Array(x,y), Array(x+width,y), Array(x+width,y+height), Array(x,y+height));
                                            doc.selection.select(selectedRegion);
                                            doc.paste(true); //paste image into masked layer your document
                                            align('AdCH'); align('AdCV');
                                            doc.selection.deselect();
                                            pasted++
                                            if ( pasted==cols ) { pasted=0; currrow++; }
    var inputFolder = "~/My Documents/My Pictures/";
    Sep 11, 2012 4:11 AM   in reply to funreizer
    Try this:
    var inputFolder = Folder( Folder.desktop + '/Output_Files' ); // Make sure this is correct for your hard coded path???
    alert( fileList.length );
    for ( var i = 0; i < fileList.length; i++ ) {
        app.open( fileList[i] );
  • JJMack
    Jan 9, 2006
    Sep 11, 2012 6:05 AM   in reply to funreizer
    Yes I was to fast with the fingers heet to be a folder object use code like  Muppet Mark  does not have to ne on the desktop and you maght want to test ir see if it exists
    var testFolder = new Folder("~/My Documents/My Pictures");
                        if (!testFolder.exists) {
  • JJMack
    Jan 9, 2006
    Sep 11, 2012 8:27 AM   in reply to funreizer
    Remember if there are a great number of large images in the folder that script will tax your system....
