Hi, I was wondering how to make time lapses in Premiere elements 10. I tried right clidking a photo and then clicking time warp and setting the time to 1 frame but I can't apply this to all the pictures. I also went to Edit, Preferences, General, and set still image default duration to 1 frame, but this does nothing.
Any suggestions??
Thanks ![]()
I have made many Time-Lapse Videos in Premiere.
There are several factors, that probably need to be tested first. The biggest consideration is the shooting interval of the Stills, and then the "look" that one wishes to achieve.
In most, I go to Edit>Preferences (before I Import any Still Images), and change the Still Duration to something around 3 - 5 Frames. Again, this is after a few tests. Then, I Import the Still Images. I also set the Duration of the Transitions, to be quite short, depending on how many Frames I have chosen.
After Import, I make sure that the Still Image files are numerically sorted, select multiple files, and drag those to the Timeline. Then, I apply the default (shortened in Edit Preferences>General>Video Transitions) to each Image.
I usually start with maybe 10 Images, and experiment with the Still Image Duration, until I am comfortable with the look, for that subject.
Good luck, and hope that helps,
Hunt
