Error Code: U44M1I210
Sep 3, 2012 5:39 AM
What does this mean?
    Sep 3, 2012 10:34 AM   in reply to PDuquette1964
    It can mean there was a problem applying an update.  What update are you trying to apply?  Which operating system are you using?  What have you tried so far to resolve your difficulties?
    Sep 4, 2012 5:58 AM   in reply to PDuquette1964
    Which update are you trying to install?  Have you tried applying the update directly from the product update page at http://www.adobe.com/downloads/updates/?
    Sep 5, 2012 9:26 AM   in reply to PDuquette1964
    Thank you PDUquette1964 although the crash report doesn't tell me to much.  Can you please try applying the update directly and also post what error you receive when trying to apply the update per message #3.
    Sep 9, 2012 12:10 PM   in reply to PDuquette1964
    So you have never been able to launch InDesign and now you are unable to apply the update for InDesign as well?  Is this correct?
    If the answer is that you have never been able to launch InDesign then please review your installation logs to determine what caused the installation failure.  You can find directions on how to accomplish this at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5 -cs5.html.
    If you were previously able to launch InDesign but are now not able to apply the update then please also review the install logs but in this case you will want to review the logs for the update located at the same location.
    Sep 10, 2012 8:10 AM   in reply to PDuquette1964
    You have several DF037 errors through your install log.  A couple of examples is as follows:
    [       1] Wed Aug 22 21:19:50 2012 ERROR
DF037: Unable to delete directory "/Library/Application Support/Adobe/CameraRaw/LensProfiles/1.0/Nikon"(Seq 241)
    [       1] Wed Aug 22 21:19:50 2012  INFO
DW063: Command ARKDeleteDirectoryCommand failed.(Seq 241)
DF037: Unable to delete directory "/Library/Application Support/Adobe/CameraRaw/LensProfiles/1.0"(Seq 288)
DW063: Command ARKDeleteDirectoryCommand failed.(Seq 288)
    You can find steps on how to correct this at Error "Exit 6" or "Exit 7" | Install log | Read, write, system file errors | CS5, CS5.5 - http://helpx.adobe.com/creative-suite/kb/error-exit-6-exit-7.html.
    Please search your install log for DF037 to locate the directories which are being reported as experiencing this difficulty.
    Sep 11, 2012 8:11 AM   in reply to PDuquette1964
    The relevant steps in the document are how to change permissions on your directories.  You may want to search your log file again as I am quite sure there was additional DF037 errors within your install log.
    If you do want guided assistance on this please feel free to contact our support team.  Our technicians will be happy to walk you through the process.
