quick,draw!
InDesign Cs4 "Cannot Open File"
Sep 11, 2012 8:28 PM
Tags: #cs4 #file #open #indesign #compatibility #cannot
Trying to open a .idd file with Cs4, but receive this message.  I have checked to make sure I have all updates and I do.  If this file was made in Cs5 or Cs6, it should still be compatible with Cs4.  Can anyone give me some advice?
    Sep 12, 2012 12:26 AM   in reply to quick,draw!
    Looks like the document is opened in the newer version of the Indesign.
    Open it up in CS5.5 or CS6 , save it as IDML and then open it up in InDesign CS4
    Sep 12, 2012 4:32 AM   in reply to quick,draw!
    My guess is it's a CS6 file since it mentions form fields in the list, but you can use Jongware's tool to find out: Adobe Forums: [Ann] Identify Your InDesign File
    Your OS cannot identify a file as anything newer than the most recent version you've installed, which leads to a lot of confusion, and no, newer versions are not backward compatible -- never have been in ID. To move files back to earlier versions they must be exported as interchange format files from the version where they were saved. Since CS4 that has been .idml, and all versions of ID since CS4 can read .idml exported from any version, but unsupported features from newer documetns will be lost and text will probably reflow, so you shouldn't have any expectations of a perfect conversion.
